Understood. The HT2-TL (or preferably the SS8 if in the budget) would fit the bill. Given that your speakers are fairly close to the wall behind them (I believe you mentioned 18"), I hesitate to recommend the HT3. I also am restricted in how far out I can place speakers so Jim advised one of the TL designs or SS (with side firing passives) since they are less sensitive to placement in terms of bass performance. He said the HT3 would likely be too boomy in my room/setup.
I'm not sure of your reasoning here. Are you saying that the two models are so similar if not taking advantage of the bass response that I should save my money (floor space and back) or something about the smaller SEAS that you think is advantageous?
Yes.
The smaller SEAS would have wider disbursion, especially in the upper part of its range, which may give it an advantage in terms of disappearing in the soundstage. Also, you save $1k.
Originally Posted by pstrisik
Why is that? Are you making a general statement about their awesomeness? Cost, size, weight are all factors for me. Being in Alaska increases the issue with weight - shipping costs a fortune and I'll be moving them back to the lower 48 eventually. Again, I have to really want them to justify the cost/weight factors.
Based on what I've heard (SS10), the SS line is awesome! Only you can decide if it's worth the cost difference (not an insignificant amount).
Personally I look at it this way. As long as I can afford it, I'd rather pay more to get the best I can. It may be painful to part with all that money at first, but down the road I will have forgotten all about the money and will be enjoying great sound.
When I was shopping for a TV back in 2008, I had a hard time justifying the cost of the TV I really wanted (Pioneer Elite Kuro). In my mind, the Panasonics were a much better value. But then I thought, in a year do I want to watch a movie thinking "what a fantastic picture" or "what a fantastic value"? I chose the former and have been in Kuro heaven ever since with absolutely no regrets!
I think I'm more strongly leaning towards the HT2-TL over the STSC at this point so far. No sure about moving up to SS. The HT is the leading contender.
For me, the deciding factor would be if I wanted/needed the HT2-TLs bass output abilities. If not, the SCST, if so, the HT2-TL. BTW, relieved of bass duties, I think both would have plenty of dynamic range.
That's what I want to hear! Makes things simpler. If I'm going to be keeping grills on, I'd leave the offset as the master intended. And thanks for digging up that post from him.
WRT to active/passive... the trouble is I can understand just enough to get myself in trouble with obsessiveness. After all of this discussion, the bottom line is that I will likely be thrilled with most any of the options considered as it would be quite a leap from anything I've had. I still have to consider every option though. I can't help myself!!!
Speaking of grills, I had Jim also install magnets under the veneer on the back of my HT2-TLs. That way if I want to listen sans grills, I just pop them on the back........keeps them securely and safely out of the way.
If you decide to get one of the models with an offset tweeter, next you can obsess over whether to place them with tweeters to the outside or inside (mine are to the outside).
Of course I just tease........it took me a year to decide on speakers and many months after delivery to set them up to my satisfaction.
Decisions, decisions.......
