Last Update: 5-Jul-2011
Google SSP Spreadsheet is the source for the table. Please feel free to update the "Next Version" tab of the table. I will edit and promote to this posting as it evolves.
Feature Legend:
Feature Legend:
- Codec
- HBR - native High Bit Rate Decoders: Dolby Digital TrueHD, DTS-HD MA (and MPCM)
- MPCM - multi-channel PCM over HDMI (either 6 or 8 channels) support only
- HDMI Version
- HDMI 1.0 is required for MPCM
- HDMI 1.2 is required for SACD DSD format
- HDMI 1.3 is required for HBR format
- HDMI 1.4 is required for 3D Video
- Video Mode
- VS - Video Switching - only switches HDMI inputs to output & limited transcoding
- VP - Video Processing - supports video processing features beyond switching & transcoding, which may include noise & cadence management, aspect ratio management, anamorphic support, colour management.
- Surround Mode
- THX -THX audio processing modes supported (and DPL as well)
- DPLIIX - Dolby Pro Logic IIx Movies & Music modes supported
- DPLIIz - Dolby Pro Logic IIz for support of additional height speakers
- HBR Surr. - can the Surround Mode be applied to the HBR bitstream codecs (TrueHD, DTS HD MA)?
- Decoders
- DSD - native SACD DSD over HDMI decode
- HDCD - High Definition CD
- Spkr X-Over - Speaker Crossover:
- Fixed - 80Hz for all speakers
- Single - one adjustable crossover value applied to all speakers
- Pair - adjustable crossover value per pair of speakers (F/C/S/SB/SW)
- Custom - adjustable crossover value per speaker
- Room Correction
- None
- GEC - Graphic Equalizer (fix band freq domain only)
- PEQ - Parametric Equalizer (freq domain only)
- Lexicon EQ
- Audyssey - MultEQ, MultEQ XT, MultEQ Pro
- Trinnov
- Analog Bypass - can the SSP be used as a pure preamp passing analog inputs through a pure analog path?
- Feature boxes that are blank (empty) mean that the feature behaviour has not yet been determined.
