Parasound C3 was spotted at CEDIA:
http://blog.hometheatermag.com/cedia...ts_a_new_halo/
Unfortunately no additional details of substance.
More interesting is
Chris D's post on HTGuide which shows the XLR based C3, the RCA based HDP 70, and a Parasound AVR - HDR 77. The back panels look extremely similar excepting XLR for the C3 and speaker 5ways for the AVR.
Chris also posted the common details between the platforms in the
HTGuide Initial CEDIA '08 report, new Parasound gear thread:
- 5 inputs, 1 output HDMI 1.3a, Deep Color, xvYCC
- Decodes all audio formats, through HDMI and otherwise, including DTS-HD Master Audio and Dolby TrueHD. (note: I asked about the niche format of Windows Media Video High Def, and this is probably not included)
- Can upscale (and transcode) all video from any source to 1080p over HDMI
- Likely upscales to component video also, unknown resolution
- Can display on-screen display on HDMI
- Automatic room calibration and equalization
- 3 independent audio zones
- new front "portable input" jack
- Pure analog routing options (you can choose to make ANY analog audio source straight pass-through, not just the multichannel inputs!)
- Independent crossover settings for all speakers
- Two pairs extra assignable fixed and variable outputs. (note that these are NOT the fully programmable channels in previous C1/C2 though)
- Assignable outputs can downmix any surround channel input to 2-channel, so you can watch your BD in the theater in surround sound, or leave to the bedroom zone 2 and keep watching it fully downmized to stereo
- Dual powered IR flasher outputs
- Four 12V triggers (2 programmable)
- Two-way RS-232
- Rear special ipod player jack that will be able to stream PCM from the ipod as well as access song/metadata. This will be one of only two known units to have this!
- 192khz audio processing
- Dual Cirrus DSP chips - one decodes the bitstream, the other handles the post-processing
- Faroudja video scalar
- USB input for firmware updates, may possible enable computer customization like HaloControl
- Improved bass management
- multichannel analog inputs jacks are still straight passthrough
- Still unsure whether Parasound will pursue THX certification
- All S-video inputs have been eliminated except 1
- 3 component inputs, 1 output
- Zone 2 has composite video in addition to audio
A shot of just the HDP 70 alone:
http://blog.hometheatermag.com/cedia...e_classic_avp/
