The specs of the ADA Cinema Rhapsody Mach IV flagship HT preamp controller are on the official website now:
http://www.ada.net/products/ht/cinem...sody_mach4.php
- Dolby TrueHD & DTS HD Master Audio
- Multi-Channel (192KHz/24 Bit) PCM Audio
- Full 7.1 EX/ES, THX Ultra 2, Dolby Pro Logic IIx, DTS Neo 6
- 8 HDMI Inputs with HDMI Equalization Settings per input
- 2 (Dual) Mirror HDMI Outputs with HDMI Equalization Settings
- Parametric Multi-Band Equalizer
- 8 Stereo Analog Audio Inputs
- 6 Digital Audio Coaxial Inputs
- 2 TOS-Link Optical Digital Audio Inputs
- 8 Channel DVD Audio/SACD Input With Bass Filters
- 8 Composite Video Inputs
- 8 S-Video Inputs
- 8 Component Video Inputs
- Analog And Digital Audio Record Outputs (2nd Zone)
- 2 Main And 2 Record (2nd Zone) Composite Video Outputs
- 2 Main Component Video Outputs
- Rear Panel Ethernet Connection (ADA Net)
- 2 Programmable Low Voltage Output Triggers
- ADA MX-900 (Universal Remote Control) Included At No Additional Charge
- 90-260Volts AC 50/60Hz 40 Watts
- 23 lbs 3.5"H x 19"W x 17.5"D
The "Trinnov" logo is on the front faceplate.
The Mach IV looks mighty impressive by the look of things. Can't wait for user reviews.
- 8 S-Video Inputs
