AVS › AVS Forum › Audio › Receivers, Amps, and Processors › SSP & Pre/Pros that support HDMI Audio MPCM
SSP & Pre/Pros that support HDMI Audio MPCM - Page 34
post #991 of 1049
Originally Posted by Kal Rubinson View Post
Was that in doubt?
The table in the first page shows that Classe SSP-800 can do HBR but not MPCM.
post #992 of 1049
Then it was posted in error since all multichannel AVRs/processors with HDMI input, beginning with v1.0, will do multichannel PCM. In other words, if it will do HBR, it must also do MPCM
post #993 of 1049
post #994 of 1049
Originally Posted by rblnr View Post
Cary has announced the Cinema 12:
http://www.caryaudio.com/products/cinema/cinema12.html
It doesnt seem much different than the 11a with the hdmi 1.4 upgrade. What am i missing?
post #995 of 1049
Only 1 hdmi output??
post #996 of 1049
Is that different?
post #997 of 1049
No that is not what it says. HBR implies MPCM. MPCM does not imply HBR.
post #998 of 1049
What is the MSRP on it?
post #999 of 1049
Originally Posted by Eric Carroll View Post
Last Update: 20-Feb-2011
Google SSP Spreadsheet is the source for the table. Please feel free to update the "Next Version" tab of the table. I will edit and promote to this posting as it evolves.
Feature Legend:
  • Codec
    • HBR - native High Bit Rate Decoders: Dolby Digital TrueHD & DTS-HD MA
    • MPCM - multi-channel PCM over HDMI (either 6 or 8 channels) support
  • HDMI Version
    • HDMI 1.0 is required for MPCM
    • HDMI 1.2 is required for SACD DSD format
    • HDMI 1.3 is required for HBR format
    • HDMI 1.4 is required for 3D Video
  • Video Mode
    • VS - Video Switching - only switches HDMI inputs to output & limited transcoding
    • VP - Video Processing - supports video processing features beyond switching & transcoding, which may include noise & cadence management, aspect ratio management, anamorphic support, colour management.
  • Surround Mode
    • THX -THX audio processing modes supported (and DPL as well)
    • DPLIIX - Dolby Pro Logic IIx Movies & Music modes supported
    • DPLIIz - Dolby Pro Logic IIz for support of additional height speakers
  • HBR Surr. - can the Surround Mode be applied to the HBR bitstream codecs (TrueHD, DTS HD MA)?
  • Decoders
    • DSD - native SACD DSD over HDMI decode
    • HDCD - High Definition CD
  • Spkr X-Over - Speaker Crossover:
    • Fixed - 80Hz for all speakers
    • Single - one adjustable crossover value applied to all speakers
    • Pair - adjustable crossover value per pair of speakers (F/C/S/SB/SW)
    • Custom - adjustable crossover value per speaker
  • Room Correction
    • None
    • GEC - Graphic Equalizer (fix band freq domain only)
    • PEQ - Parametric Equalizer (freq domain only)
    • Lexicon EQ
    • Audyssey - MultEQ, MultEQ XT, MultEQ Pro
    • Trinnov
  • Analog Bypass - can the SSP be used as a pure preamp passing analog inputs through a pure analog path?
  • Feature boxes that are blank (empty) mean that the feature behaviour has not yet been determined.
The Onkyo PR SC5508 has Audyssey XT32w
post #1000 of 1049
Thanks! I added the change to the spreadsheet. Should appear next time he updates it on the first page.
post #1001 of 1049
Man... it certainly seems like it's been a long time since any manufacturer releases or announcements. Have we been missing things or are things just that quiet?
post #1002 of 1049
The Cinema Rhapsody balanced is $7500
post #1003 of 1049
Added it. Thank you.
post #1004 of 1049
Post #1 has been updated. Changes:
4/26/2011 eric carroll B&K Ref 70 RIP
4/3/2011 Roger Dressler SSP-800 5 HDMI, 7.3 out
5/19/2011 Ronf Primare Sp32HD 3 HDMI, 7.1 out
6/29/2011 pgwalsh Cinema Rhapsody $7500
7/5/2011 eric carroll Cary Cinema 12
post #1005 of 1049
and honestly, who could possibly be interested in their HT products ? well, of course. unless one is completely unaware, but considering what happened with the 11a, dude it was a clown show.
post #1006 of 1049
NAD has announced the MV15 video upgrade module for the M15 HD.
Features include:
  • Full support for available HDMI 1.4a features
  • All mandatory 3D video formats up to 1080p/24
  • Audio Return Channel
  • Consumer Electronic Control
  • 6 HDMI Inputs and 2 HDMI Outputs
  • Supports analogue-to-digital conversion for video signals to HDMI
  • All sources are output with their native resolution
  • Ethernet Port allows network control of the M15 HD Surround Sound Preamplifier
Shipping Sept 2011.
post #1007 of 1049
Bryston is saying Oct for the SSP-3.It is in production now.
post #1008 of 1049
While reading my just arrived Home Theater, I noted an ad from Sherbourn presenting their new PT-7020C4 pre/pro with all of the requisite bells and whistles. No idea of date of availability but if they are taking our ads, it shouldn't be too long.
Sherbourn has been identified with some great values, especially in amplification in the past, and typically undersell their competition by a very significant margin. They also announced their 7 channel 350wpc into 8 ohms power amp, the PA 7-350 in the same ad.
Based on the pre pro's appearance looks like it might have been sourced from Anthem, but that would not seem to fit into the "value" platform that Sherbourn has always been associated with.
Here is a link from their web page, where it simply states - coming soon.
http://www.sherbourn.com/index.php?o...d=12&Itemid=26
John
post #1009 of 1049
John
Not sourced from Anthem, afaik, and not as inexpensive as their initial line.
post #1010 of 1049
Re the Sherbourn:
Does the back look like an Anthem at all?
Automatic Cirrus/Sherbourn multi-channel room calibration and loudspeaker setup, with the included calibrated measurement microphone
post #1011 of 1049
Originally Posted by Kevin C Brown View Post
Re the Sherbourn:
Does the back look like an Anthem at all???
You tell me.
post #1012 of 1049
Seeing as how Sherbourn is now owned by Emotiva, I really doubt that they will be rebranding anything under their name made for them by Anthem. I'd wager from here on out, anything in the Sherbourn lineup will be based on either a older Sherbourn design, with some of newer stuff being possibly designed and made by Emotiva's supplier in China.
post #1013 of 1049
You tell me.
Dang, I had to go look for myself.
And the answer is ... no.
Not like the back of the Outlaw 978 either, which was my guess.
post #1014 of 1049
Seems like the list should be updated with the Integra DHC-80.3 and Onkyo PR-SC5509
post #1015 of 1049
Rotel RSP-1572
The RSP-1572 is Rotel's latest 7.1 surround sound preamplifi er. Its advanced design builds upon a progression of outstanding home theater processors that have received critical acclaim around the globe. The RSP-1572 features important new technologies such as HDMI 1.4 with 3 D capability. It offers six HDMI inputs and two HDMI outputs with one HDMI output having ARC capability (Audio Return Channel). The ARC in HDMI 1.4 enables a TV via a single HDMI cable, to send audio data upstream to an A/V receiver or surround audio controller, increasing user flexibility and eliminating the need for any separate S/PDIF audio connection.
MSRP $2199 Rotel Info Sheet
post #1016 of 1049
Originally Posted by TommyV View Post
Rotel RSP-1572
Decent price, but I'm surprised it doesn't have balanced outputs. Is this typical for rotel?
post #1017 of 1049
Review of Rotel RSP-1572 in March Stereophile.
post #1018 of 1049
Seems that way just like they have dropped Class A/B multi channel amps. I personally don't want XLR outputs but a Class A/B RMB-1075 replacement would be nice.
post #1019 of 1049
I like XLR because they lock in nicely and look cool, which is pretty lame reason, but I'm sticking with it.
Are they using digital amps? I heard they were using the Bang and Oulfson units, is this correct?
post #1020 of 1049
They have been focused on D amps for a while. Based on B&O ICE technology. Never heard their amps though.
