Originally Posted by
wajo
Yes, that sounds good, except 3) using Composite and 4) using S-Vid will require you to install 3) in back w/o any menu changes (just select L1 as source when viewing/recording from VCR), but 4) will have to go in front so you can separately change L2 Video Input option to S-Video. You CAN plug both Composite and S-Vid in back or in front, but then you'd have an extra step to differentiate the inputs via the Video >Video Input menu, i.e., can't see both on back or in front individually w/o a menu change.
One advantage to connecting both in back (or front) is you only need one set of R/W cables for audio for either type.
Check out Monoprice.com for excellent cables, one of AVS's sponsors, small add at top of each page. They are the only source I've found for HDMI with ferrite core on each end to reduce interference.
Wajo,
I'm probably not replying in right place for this, but now that I've looked at things a little more closely, is there any reason why I couldn't connect my dvd player and VCR via composite cables to the Magnavox 515 DVDR (VCR in back; DVD in front), since I have mutliple composite cables on hand? I don't mind the cables being visible as long as I don't have to plug/unplug them. We're used to changing sources on various remotes, etc.
I originally thought, "oh, we need to try S-Video since that allows for better video" while not FULLY processing that I still need the L/R audio cables that are included in the composite cable "package." I was thinking that I'd have too many composite cables than I had inputs for (still thinking about the TV). But if the Magnavox DVDR is going to "communicate" with the TV via HDMI, than wouldn't I only need an HDMI from monoprice (with maybe a port saver or two)?
Clearly, we are not "home theater" people.
Oh, we decided on the un46c6300 'cause we found it at a great sale price. We could argue that it's not QUITE big enough, but it's great so far.
