Originally Posted by Almost there
I live in South NJ (near Philadelphia) and Comcast just changed their broadcasting format which has made my existing VCR/DVD R unusable.
Before spending $250 for the Magnavox MDR515, I purchased an RCA Digital TV Converter (# DTA800B1) (= converts over the air TV broadcasts for use on analog TVs) hoping that I could still use my VCR/DVD R. However, I still received the message on my TV screen that I needed a Comcast device to view the channel.
Anyone know how I can make it work?
I'd try putting an antenna on the converter box. Depending on how close you are to the Philadelphia antenna farm (Roxborough), simple rabbit ears might be enough. I brought my old analog Pioneer VCR/DVDR back to life with a similar converter box and a simple home made antenna in the attic.
For general antenna info see:
http://www.avsforum.com/avs-vb/showthread.php?t=381623
Philadelphia broadcast area OTA discussion:
http://www.avsforum.com/avs-vb/showthread.php?t=620626
. Then, at 12 noon, the 515 made its usual time check and set the clock back one hour
