Originally Posted by
wajo
Besides trying Bodhi78's solution above, do a test for me: use your normal copy-to-PC procedure BUT FIRST DELETE the Video_RM folder so your apps don't even see it... just to see if the structure looks more normal from the get-go.
I have done this many times. Also ripped with DVD decypter, with and without AUDIO_TS folders, etc. I ran procmon to look at DVD shrink, and all that program looks at is the VIDEO_TS folder and then runs through all the ifo and vob files that are in the folder.
I'm pretty sure the problem is the ifo file that the 2160A is creating. Some programs can use it, some can't, but even the ones that can use it show two titles for every physical title on the disk.
This is what the PGCedit program shows for the disK:
DVD: "D:/VIDEO_TS"
DVD-TEXT General Name: ""
Provider ID: "DVD-VR01"
Number of VTS: 1
VMG , First-Play PGC
VMGM , LU 1 (--) , 1 (0:01) 33b. TitleM (Programs: 3, Cells: 3)
VMGM , LU 1 (--) , 2 (dummy)
VMGM , LU 1 (--) , 3 (dummy)
VTSM 1 , LU 1 (--) , 1 (dummy) RootM
VTST 1 , 1 TTN 1 (1:34:06) Title 1 (Chapters: 1, Programs: 1, Cells: 23)
VTST 1 , 2 TTN 2 (1:03:57) Title 2 (Chapters: 1, Programs: 1, Cells: 16)
VTST 1 , 3 TTN 3 (1:22:56) Title 3 (Chapters: 1, Programs: 1, Cells: 20)
VTST 1 , 4 TTN 4 (1:35:55) Title 4 (Chapters: 1, Programs: 1, Cells: 23)
VTST 1 , 5 TTN 5 (0:01) Title 5 (Chapters: 1, Programs: 1, Cells: 1)
VTST 1 , 6 TTN 6 (1:34:06) Title 6 (Chapters: 1, Programs: 1, Cells: 23)
VTST 1 , 7 TTN 7 (1:03:57) Title 7 (Chapters: 1, Programs: 1, Cells: 16)
VTST 1 , 8 TTN 8 (1:22:56) Title 8 (Chapters: 1, Programs: 1, Cells: 20)
VTST 1 , 9 TTN 9 (1:35:55) Title 9 (Chapters: 1, Programs: 1, Cells: 23)
VTST 1 , 10 TTN 10 (0:01) Title 10 (Chapters: 1, Programs: 1, Cells: 1)
Edit: I should note that I did no editing of the DVD before finalizing. My guess is that the apparent ifo problems are due to the way the data are written for -VR editing on the disk. I suppose I should burn some test disks with different titles and edits and see what the difference is in the resulting DVD files.
scott s.
