AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575
Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 6
post #151 of 23750
I'm sorry I started these reactions
I wish I could find such an extensive forum about 3570, but it seems there isn't.
To make things worse, 3570 supports writing to the USB, but only certain file types (mp3, wma, divx and jpeg). TV recordings can only be copied to DVD.
But, enough with the differences, what brought me here are the common features. I didn't get the unit yet, but after reading about 3575, I'm already sure I couldn't make a better choice
post #152 of 23750
Thanks for all the discussions and detailed response - it help to push my purchase decision!
post #153 of 23750
I looked at this unit for ~$300 and cost of upgrading my cable box to an HD DVR and found the additional cable bill for 4 years is about $300..
Since about half of the programs I want to time-shift are in HD, I'm going to have to go for the HD DVR rental. (For now).
Cheers,
Rich
post #154 of 23750
Originally Posted by wabjxo View Post
*Cables, Connections and Special Settings*
[indent]Note 1: Satellite users need to consult their installation guide or setup manual for info. I think you can set up the same way as described here, but some people say you can't use the normal coax connection, while others say you can but it's "better" thru a line connection, like the "AV IN" connectors on the back of a DVDR.
Connecting the Incoming Coax thru 3575 and on to TV
Over-the-air (OTA) antenna and cable TV users should start by connecting the incoming coax to the 3575, then continue the coax on to downstream components, such as a cable box and TV. (If you have a cable box, you may have some or all unscrambled channels, but you won't know for sure until you scan for channels with the 3575, so it needs to be 1st in line for the coax for now.)
Wabjxo, due to your awesome info, I stopped by my local walmart last night and bought me one of these. Never had a recorder, and thought it was time. One clarification, if I already have Directv's HD DVR (HR20), I did not think I could "split" the coax coming from the dish. Since there is no "coax out" on the back of the HR20, are you saying I can run the coax from the dish to the DVDR, and then out from the DVDR to the HR20?
What benefit would that give me since I already have the DVR for pause, recording, etc etc.
Or should I just run my S video from the HR20 out to the in on the DVDR, as well as the audio out from the HR20 into the DVDR, and not mess with the coax and leave it as it is (I only have the two coax ins on the back of the HR20)
thanks for the great info, looking forward to setting this up.
post #155 of 23750
You know, your post is interesting since I've been browsing other forums and one cable tech advised that all cable boxes had a coax out, so this means satellite is different in that respect, as well as requiring the satellite provider's proprietary box?
Another unknown, as indicated in Note 1 as you quoted, is whether you CAN run the incoming sat coax into the 3575 1st and record any channels that way. Some sat users said no, some said only that it's "better" thru S-Vid, others say they rec that way all the time??? I'm totally stupid when it comes to satellite!
Anyway, with no coax out and assuming all signals have to go thru the satellite receiver (i.e., the 3575 can't tune ANY channels directly), you're right in using S-Vid to the 3575 from the H20. You should get awesome recordings that way. Don't forget to set the Video > Video Input option to S-Video In (default is Video In...composite).
I'm not sure if your sat provider has PPV or other "on-demand" services, but I'm still looking for someone who sets the 3575 1st on the coax and orders stuff thru the providers coax (not a separate tel. line) to tell me if the 3575's coax passthru is bidirectional or if it blocks comm. with the provider, i.e., on-demand doesn't work.
Hope you enjoy your 3575 as much as I do mine!
post #156 of 23750
Cheers,
Rich
That's certainly an option many people choose, however, anyone who wants to copy home videos to DVD, or save some programs to DVD, or play commercial DVDs, or just needs time-shifting w/o full HDTV PQ won't be best served by a cableco DVR alone.
post #157 of 23750
I'm not sure if your sat provider has PPV or other "on-demand" services, but I'm still looking for someone who orders stuff thru the providers incoming coax (not a separate tel. line) to tell me if the 3575's coax passthru is bidirectional or if it blocks comm. with the provider, i.e., on-demand doesn't work.
thanks.., I think I will try leaving the coax the way it is, and run the s video and audio outs on the hr20 to the philips.
I mainly want the best possible source for recording to dvd either via directv or my dvr camcorder. I have a sony xbr 1080p tv, so I want to learn how to get the 16:9 display from my recordings w/o distortion.
Re. Directv PPV and on-demand - ppv only requires a phone line if you wanted to order ppv via the box, otherwise you don't need it and can order ppv via their web site. on-demand (beta) for directv is via the ethernet/internet connection on back of the hr20, not via a phone line. in other words, you do not need a phone line for updates, on-demand, etc for directv. appreciate the help, I am sure I will have more follow up ?'s after reading the vols of info here .
post #158 of 23750
I've been reading a lot about problems in maintaining the correct aspect ratio when using boxes that output via S-Vid or composite... apparently won't preserve the 16:9 format? Some boxes DO output 16:9 via Component, but there are no current DVDRs with Component inputs... Polaroid 2001G was last one.
Hope you're successful!
EDIT: Here's a guy who says he's been making 16:9 and 4:3 recordings from a H20 for a long time. Might hit him up if you have any problems?
post #159 of 23750
thanks for the link.. I had a chance to work with the player a little, it is great, and very happy with the purchase. Will try burning some DV camcorder footage later today. Tried some simple recordings from HR20, both on the fly and what I had on the DVR- no problems at all, and quality looked great when played back on DVD.
A couple of questions, since I am not using the coax in from the dish, and only the s-video (e1) from the HR20, does the DTV/TV button on the remote serve a purpose, or does it matter if I have DTV selected via that button when recording? I assume that is only for the coax in and does not matter in my case, correct?
After recording titles (I think it was to DVD), it said "finalizing" after each title recorded, but seems like I need to finalize the disk when completed as well? easy to do, I just thought it was finalized when it showed that screen when I was initially recording, so initially, the DVD-R would not play in my other dvd players until I finalized the disk. the first "finalized" confused me. They played no problem on other player and on my computer - cool.
Regarding record modes, one record mode for recording and one for dubbing. Will use "high" for dubbing, but if high is not used, should the dubbing rec mode be the same as the initial rec mode, or does it matter?
Can I play mpeg videos on the 3575 burned to a dvd-r from my computer? I tried, but did not seem to work.
I can't seem to find the remote code for the philips to work on my HR20 remote. I will try the above link you provided on the hr20 as well, see if any luck there. Anyone here with suggested codes?
Again, the info here is great, and makes me like the player that much more. The more I learn about it, the more I like it. Video/ movies dvd's also look great on the sony xbr. thanks!!
post #160 of 23750
The DTV/TV button just switches the tuner from one to another... N/A in your current setup.
After recording titles (I think it was to DVD), it said "finalizing" after each title recorded, but seems like I need to finalize the disk when completed as well? easy to do, I just thought it was finalized when it showed that screen when I was initially recording, so initially, the DVD-R would not play in my other dvd recorders until I finalized the disk. the first "finalized" confused me. They played no problem on other player and on my computer - cool.
The message at the end of a dub is just "advising" you to Finalize. As you found, it doesn't normally auto-Finalize, except in two specific instances set in the Recording > Auto Finalize menu: Disc Full or End of Timer Rec. I don't see those as being particularly useful in normal op. tho? You have to use the Disc Edit menu. I think the designer knew you might be doing multiple-session burns, so a truly automatic Finalize would defeat that. Too bad they didn't include a dubbing menu option like my Pio 640 which allows you to select Finalize or not for each dub session.
No, dubbing rec mode is always preferred to be High cuz there's no loss in quality that way.* However, in the Dub menu you CAN choose any mode you want, like maybe you want to add titles in multiple sessions and have figured that LP will fit things you want to get on one disc in later sessions, etc.
*Not too sure about that "loss in quality" with the 3575... it's a good theory and might apply if recording an analog channel or using the lower-quality modes, but I did a worst-case test of HQ mode making 6 generations... no High involved, all real-time... w/o any "visible" loss... see this post for more info if interested.
I don't play MP3 but the manual says they are playable from a CD-R/RW or USB. That must be true based on your experience?
Don't know, hope someone else can help. That averagejoe poster I linked to above who uses the same equipment as you might know?
post #161 of 23750
...A couple of questions, since I am not using the coax in from the dish, and only the s-video (e1) from the HR20, does the DTV/TV button on the remote serve a purpose, or does it matter if I have DTV selected via that button when recording? I assume that is only for the coax in and does not matter in my case, correct?...
The DTV/TV button is only for switching between
the built in Digital (DTV) or Analog (TV) tuners.
If you're using an outside source instead of the
built in tuner it has no function AFAIK.
post #162 of 23750
An interesting observation about playing computer-written DVD+R Dual Layer discs in the 3575:
I mentioned some time ago in the original 3575 thread that I had no success playing back DVD+R DL discs recorded by my computer's LG DVD writer in the 3575, either Verbatim or Memorex brand. I eventually happened across one of my DL discs that played perfectly, although it was from the same batch and recorded in the same DVD writer. What was different was the Book Type - that particular disc was created with the Book Type set to DVD-ROM. As an experiment, I took a disc which didn't play successfully, recopied it in the same computer DVD writer to the same brand of DVD+R DL disc from the same batch, but with Book Type changed to DVD-ROM. Sure enough, it played perfectly. A second experiment with another DL disc that didn't play showed the same result.
Although the 3575 still shows the disc type as DVD+R when it reads it, it seems to handle it much better when the Book Type is overridden to DVD-ROM.
Unfortunately my Nero 6 software doesn't know how to set the Book Type with my current LG DVD writer (although it did with my earlier LG drive - go figure!), so I have to burn to a .nrg image file and then use ImgBurn to burn to disc and set the Book Type.
post #163 of 23750
Good luck. I've tried a few universal remotes from the stores, and I'll be darned if I could find one that'll work it.
It must be too new, and it's probably not made by the same outfit that made any of the past ones.
There is a newer, Philips remote I saw at Target recently which I might try. I believe it has DVR buttons, so it might also work your D* unit, if it's a DVR. It has a black faceplate, rather than those older, all-silver, cheaper-looking ones.
post #164 of 23750
Originally Posted by amesdp View Post
...Although the 3575 still shows the disc type as DVD+R when it reads it, it seems to handle it much better when the Book Type is overridden to DVD-ROM...
I've always set the booktype to DVD-ROM in my computer
drives (Light-ON and BenQ) even for DVD+R (SL) discs.
post #165 of 23750
On DVD-ROM: In 2006, a German magazine did compatibility tests on -R and +R discs and found that -R was 95% compatible, and +R was 93% compatible, but +R also went to 95% compatible if it was bit-set to ROM.
So... don't give non-ROM-set +Rs to the 2% of your family members who are R-negative!
post #166 of 23750
Take a look at the Sony Universal Learning Remote (RMVL600), $25 at Circuit City. I have one and it is wonderful. It can control 8 components. I use it for all my components including my Panasonic E-85. It has no code for the E-85 but since it is a learning remote, it took me about 10 minutes to program the E-85 remote codes into the VL600. I was able to customize the button mapping the way I wanted it -- not only for the E-85 but even for the other components for which there was a built-in code.
post #167 of 23750
Philips has two 15-unit remotes w/LCD screen, pretty pricey tho.
The SRU8010 has been out awhile and is discussed some in a SRU8015 thread in AVS here.
B&H Photo has it for $79.00 here.
A new SRU8015 looks very much like the 3575 remote in many respects. B&H Photo shows this as available for a mere $199 (other places ~$160).
The 3575 really needs a learning remote and lots of "logical" buttons for the 3575's 47 buttons... so you don't have to use a "Sleep" button for Disc Menu or something that'll make your signifcant other throw the remote at you when you start explaining what each button does!
post #168 of 23750
Originally Posted by Chuck44 View Post
Just be advised - opening the unit (there's a seal that will break) will void the warranty.
I wonder if you applied a bit of heat with a heat gun or hair dryer if it might make it nearly fall off by softening the adhesive? I seriously doubt they put some advanced adhesive that would prevent softening by using heat or discoloration of the sticker. I think they tried to be as frugal as they could with these, so you might give it a try if you are willing to risk the consequences.
I have NOT tried this with the DVDR3575H, but MANY times a little heat will make seals virtually fall off and then once they're cooled they stick back just like new
post #169 of 23750
It's spelled H-a-r-m-o-n-y.
post #170 of 23750
No, it's spelled D-I-V-O-R-C-E... even with a H-A-R-M-O-N-Y!
It's called C-H-A-N-G-E!
post #171 of 23750
thanks.., I think I will try leaving the coax the way it is, and run the s video and audio outs on the hr20 to the philips..
I've had satellite off and on for several years but not with the 3575 hooked up. The coax between the sat box and the LNB on the dish is a 2 way cable. The sat box passes a DC tuning voltage of around 8v for one set of transponders and 13v for the other transponders depending on the polarization of CW or CCW (the old analog satellites had vertical and horizontal polarization). The digital signal comes back down the coax and into the box as a scrambled digital signal to be processed by the smart-card. The card determines in real time if you are authorized to view the channel you are tuning in and decrypts the signal if you are allowed to watch it and displays a message to call in and buy the channel if you are not authorized. If you buy a PPV event, the purchase info is stored on the card and the sat box uses a modem to phone home periodically and upload the purchase history to the sat provider so they can send you your monthly bill.
So sticking the 3575 between the sat box and the LNB would not record any picture since you need the smart-card to process the signal and the rest of the sat box to turn the signal into something you can watch.
post #172 of 23750
I think it's well established that you need a line connection from a sat box to a line input on the 3575 to record the sat's "encrypted" signal.
I think ROKYMTN has this setup for recording and was just asking about keeping the 3575 1st on the incoming coax for the added boost the 3575 gives to its coax passthru.
What I've been waiting for is confirmation that the 3575 being 1st on the coax will or won't prevent comm. with the sat provider for ordering and billing.
From your description, it appears there is no problem with the 3575 being 1st on the coax and people CAN order/watch PPV or other on-demand TV normally since the comm. is via a tel. line?
post #173 of 23750
Sorry if I misunderstood. I don't currently have satellite so I can't test it out, but if the 3575 will pass the DC voltage back to the LNB for tuning, it should work, but I'm not sure why he would want it between the LNB and the sat box anyway since you cannot record the incoming signal. The ordering of the PPV is done in the sat box and noted on the smart-card for billing later as I described above. The sat box acts as the tuner and passes the decrypted signal to the 3575 via the S-Video in port so having it in between the LNB and sat box would seem unnecessary to me unless the 3575 acts as a digital signal booster LNA to boost a weak signal from the dish on a very long cable run to the sat box.
post #174 of 23750
That's the idea... the added signal boost from the 3575's amplified splitter/passthru!
It seems to work OK... haven't heard from ROKYMTN or other sat user otherwise yet.
post #175 of 23750
Actually knowing that the coax from the dish to the sat box, has DC voltage on it, I would be very reluctant to place the 3575 between the 2. I'm not sure how the 3575 would handle DC voltage, on a coax line, where there is normally no voltages. I do know when I used to have a mast mount preamp for my regular antenna, it had the power xformer inside the house. It would use the coax to xmit the power up to the preamp, and there was specific instructions to NOT have any device between the xformer and preamp. It said the DC voltage on the coax line could damage any device between the 2. Just a thought. I'm sure cable TV would not have such a voltage to worry about.
post #176 of 23750
Well, that's certainly a concern and I've PM'd RKYMTN to see if he's running this way, etc.
ANYONE ELSE ON SATELLLITE SERVICE WITH INFO ON THIS.... DC VOLTAGE ON THE INCOMING COAX FROM/TO THE ANTENNA PASSING THRU THE 3575???
post #177 of 23750
wabjxo...
received your pm.. I have not tried to run the coax from the dish to the 3575, and then out to my sat receiver.
I had run an s video cable and audio jacks from the sat receiver to the 3575 with good results, so I did not try directly to the 3575 first.
If I had an RG-6 cable laying around, I could try it, but not sure if I do at the moment. Any adverse effects of trying this??
post #178 of 23750
wabjxo...
Thanks for your prompt response!
That's what we're trying to discover, except don't risk your unit by connecting the coax to the 3575 1st... I thought you were already running that way... glad you're not, now.
I guess we need someone to read their sat installation instructions and see if there's a WARNING or CAUTION about installing other components on the incoming xoax, BETWEEN THE ANTENNA AND THE SAT RECEIVER.
If there's some voltage in the coax in either direction, so far we're uncertain if there could be damage to trhe 3575 if it was in that voltage path via the coax connection.
Can you check your instructions for any such info?
post #179 of 23750
wabjxo...
With the risk of your 3575 at hand, I would not try putting it in the path from the LNB to the sat box. From your description, you have the best quality hookup already with the S-Video going to the 3575 and since you do not need any signal boost from the LNB, you are only testing for testing sake. Also be aware if you were thinking of doing it with the sat box off to see what would happen, the sat box is never off unless it is unplugged. When you hit the power button on it, you are just killing the output to the TV or other components. The power to the dish LNB is always on sending DV volts through the coax.
For my reasons stated before there is absolutely no advantage to putting the 3575 in the input coax line. If you did need the signal boosted, I believe that there are special booster amps designed for that purpose. FWIR, the digital signal is either present or not and you get a picture if you are getting the signal. The signal strength of 75 will produce no worst picture than a strength of 95. The strength of 75 means the dish is in a bad reception area or is misaligned a little and it will be susceptible to earlier rain fade. I have heard of problems with bad cables and connectors causing digital dropouts, but as long as your cable run is under about 50 feet and the crimps are good, you should have no problems with fade.
Sorry to belabor this point, but I'm an Engineer and cannot help myself.
PS; One of my other pet peeves is the Best Buy's and Circuit City's selling HDMI Monster cables for $100 to connect to your $3000 HDTV when it is passing a digital signal of 1's and 0's down a copper wire when a certified HDMI cable costing $6 will work just as well.
post #180 of 23750
First of all, I want to thank wabjxo for the wonderful selling job he did on me. I was ready to purchase a DVDR with a hard drive and he sold me on this one. I purchased it a few days ago with a Sept. 2007 pack date. Now comes the unenviable task of hooking this up to my system at home consisting of an HDTV, HD Cable Box, DVD Player, and VCR.
Here is my question, my 4 yr old HDTV has a DVI input...so does my HD Cable Box. Which do I hook the HDMI to DVI cable to from the 3575? I want the best PQ for recording not just old VHS tapes, but also I want the recorder to handle the functions my VCR had. I want to watch commercial DVD's in all their HDMI splendour.
From what ive read from wabjxo, i can connect the HDMI directly to the DVI on the TV, and use composite or S-Video from the recorder to HD cable box to record those channels (remembering that DVI requires audio cables). Question regarding about this hookup is which input from the TV do i use so that the recorder will recognize it. e.g. if the recorder is hooked to the tv via Video 7, is that where i go to record channels from my cable box? Or is there a better way.
Please dont tell me to give a try and see which yields the best result. I want to hook this up and have the best chance of success from the start. Regardless, I want to thank for wabjxo and the rest of posters on here who have supported this wonderful machine. Im sure i'll get the same enjoyment from it you are all acheiving.
  Back to Forum: DVD Recorders (Standard Def)
