AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575
Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 531
post #15901 of 23903
Hi,
Curious if anyone backs up their Magnavox HDDs? Maybe I didn't try the right search terms, but didn't find much info.
MDR513 drive is filling (faster than I can watch or archive on DVD) and I was wishing they'd have a drive backup option via the USB port - just in case. I always like to backup hard drives, but don't want to void the warranty by pulling out the HDD to do a duplication.
Also, was thinking about usefulness of a backup if the original unit goes. Has anyone transplanted a drive from one Magnavox MDR to another of the same model/firmware? Not sure about the Mag, but other commercial HDD recorders I'm familiar with (ex. TiVo Ser 2) have something tying the recorded shows to the individual unit.
post #15902 of 23903
Originally Posted by jam-h View Post
Hi,
A few people have installed a external SATA port on their unit, then they can swap drives using external SATA drive bays. This is a cold swap so the unit has to be powered down when you do the drive switch.
I found CPU Stuff CS5830 to be a good cable to use for this look at CS5830.
One issue I had with it was the external SATA cables tend to be very stiff. If the cable isn't straight going to the drive bay the DVR won't see the drive. So make sure the cable is straight going into the external bay. Look at the first post for drives that can be used.
post #15903 of 23903
Hi,
I can understand your concerns, as I watch a lot of TV and wish I could offload titles to the new terabyte USB drives. Since the Mag is SD and not HD, the interface and its feed isn't rocket science. Yet there are two items that pop up to me.
I timeshift about 24 hours of HD content per week. I use the 515H at HQ, so there is 100 hours where I can save the ABC & Fox titles with little loss of quality. Sometimes I will record a CBS/NBC title on the Mag just because I want a short term backup, and I have the room.
As for long term backups, there are series DVDs from Amazon, internet content like Hulu, and the obvious built in DVD for HSD that works great. A good quality DVD+RW will last for quite a while and moving from HDD to DVD doesn't take that long.
But you're right, using a WD 1 or 2 TB drive via USB would be nice. Then again, the price of a rebuilt 2160A where you can add a 500Gb drive is pretty low. Adding the drive is easy and you will have the backup close to you. It's probably the most cost effective solution.
Do I make backups? Only my computer, and all I care about fits on a 32Gb USB drive.
post #15904 of 23903
That's what I've concluded after considering all the factors, too. Things that you really really want to keep can always be copied to DVD+-RW and stored on your computer hard disk, and at your leisure burned to DVD+-R if needed. IMHO, try to decipher the Funai proprietary disk format is not really worth the effort.
post #15905 of 23903
Hi..I have just received the Magnavox MDR515H/F7 and have been reading many of these post...maybe too many lol. I'm going to connect this unit to a DirectTV HD/DVR Satellite receiver and just wanted to make sure that I'm doing it correctly. I'm going to use the HDMI connection from the TV to the Magnavox. Do I still need to connect the RCA jacks (red, white, yellow) and the coaxial to the Satellite HD/DVR receiver. Thank you for any help that you can offer.
post #15906 of 23903
Connection per Sketch 4 and step-by-step instructions here.
Have you seen the indexed list of help files on pg. 1 of this thread?
post #15907 of 23903
Hi..I did read the indexed list of help files on pg. 1 of this thread and sketch 4..I just wasn't sure if it was the same for the DirectTV HD/DVR. Do I need both the HDMI and YPb/CbPr/Cr conected to get the best quality for recording DVDs from the DirectTV HD/DVR or just one and if so, which do you think is the best. Thank you for your time.
post #15908 of 23903
You cannot connect HDMI or Component RGB (Y/Pb/Pr) to the Mag INPUTS since it only has Composite Yellow RCA and S-Video inputs + a single L/R audio input that supplies audio for both the Yellow and S-Video connections. Mag OUTPUTS do include HDMI and Component.
You choose which you want from your sat STB, Yellow RCA or S-Video, then make sure your Video > Video Input matches that... "Video in" for Yellow RCA or "S-Video in" for S-Video.
I've found Yellow RCA to be just as good as S-Video but many others disagree and swear by S-Video. You can try both and see which you prefer. I don't have HD service so you might find S-Video works better there?
post #15909 of 23903
Thanks for all the comments. I've seen some of the drive "farm" postings. Interesting stuff. Also interesting about expansion by 2160s, but they don't seem to be commonly available lately. (Only see the 513s.) Yep, offloading titles to external disk would be super, but I'd be happy with a backup against drive failure - even if it were a (reasonably priced) proprietary Magnavox external USB.
Backup would be great if it could be moved to a replacement unit if the Maggy itself failed.
Anybody ever try a 513<->513 or 513<->515 drive swap - maintaining recordings and functionality?
post #15910 of 23903
Originally Posted by helibobber View Post
Thanks for all the great advice. As per KenF.'s suggestion I removed the HDMI cable from the Cable box to TV and replaced it with component cables. I retained the RWY connection from the cable box to the DVR and it worked!
Again, thanks for the help. I'm very happy.
My Dad had same issue with his TV with the HDMI hookup as well. I think he made some calls and found out it was a software/handshake issue on the TV. (Primarily on TCM). Check and see if there is a firmware update on for your TV.
post #15911 of 23903
Haven't tried it but from what I know about the drive format. The 513 and the 2160A use the same firmware so they should be able to swap between those. 513 to 513 is for sure a go. Not so sure about the 513 to 515. I thought someone did try that and it didn't work. They do run different firmware so it maybe an issue.
If sector 2 starting at byte 16 has this text, you should be able to swap the drives with the unit.
HDDFs 00.07
That is from my 2160A that I put an external drive on for testing.
post #15912 of 23903
Originally Posted by PeterTheGeek View Post
Haven't tried it but from what I know about the drive format. The 513 and the 2160A use the same firmware so they should be able to swap between those. 513 to 513 is for sure a go. Not so sure about the 513 to 515. I thought someone did try that and it didn't work. They do run different firmware so it maybe an issue..
All three should be interchangeable w/o adapters. They each had different OEM FW, which itself is now interchangeable with the latest FW Update. The only operating part of the latest FW that changed was Back-End (BE) which doesn't include the HDD/DVD drive ops.
No one has replaced the 513 or 515 HDD yet, I suppose cuz they're already large enough for most people, and 500GB is the limit?
post #15913 of 23903
I'm trying to make sure I have the connections right on the Mag 515...I will take the coaxial coming in from the outside satellite dish and connect it to the Mag 515 first, then to the DirectTV satellite HD/DVR, and that will make it possible for me to record a dvd on the Mag 515 from the DirectTV HD/DVR while I watch a different channel?
post #15914 of 23903
No, don't connect the incoming sat cable to the Mag!
The only connection to the Mag in a sat system (Dish or DirecTV) is a "line connection" from an output on the back of the sat receiver to the Mag, and the Mag can only use Composite YWR RCA or S-Video+WR RCA audio.
That way, you can only record a single channel from the sat receiver or copy titles from the sat DVR (if you have one).
If you ALSO connect an indoor or outdoor antenna or a cable TV coax to the Mag's ANT IN connection, then you can watch a sat channel while recording an antenna or cable channel.
I assume you looked at Sketch 4 in the help files and read the step-by-step instructions, linked text, etc.? The first thing above that sketch is a CAUTION not to connect the sat cable to the DVDR.
post #15915 of 23903
Thank you for your help....I used to work with electronics in my younger days but I guess with age so goes the memory...thanks again!
post #15916 of 23903
Is there a cable connector on the back of your satellite receiver labeled "OFF-AIR IN"? If so, is there anything connected to it?
post #15917 of 23903
Can the 515 record more than 99 titles on the HDD? Thanks.
post #15918 of 23903
Yes, all HDD models can record up to 600 titles on their HDD with 99 chapters each title, as described here.
That's a FW limitation. HDD capacity is another thing and based on number of bits, hours, etc., i.e. HDD may fill up BEFORE 600 titles.
post #15919 of 23903
HDD:
600 titles
99 chapters per title
DVD:
49 titles per disc
254 chapters per disc
Edit: wajo beat me to the answer once again.
post #15920 of 23903
Originally Posted by JimLely View Post
I have a 10-year old URC8810 with the older JP-1 connector for which I have a connector cable with complementary JP-1 on one end and serial connector for my PC on the other end. I hear that the 8820 has the newer JP-1 that requires a different connector cable. Can you confirm?
Jim
The 8820 and the RCRP05B also recommended in this thread do use the newer JP1.2/3 connector cable.
post #15921 of 23903
The 513 and the 2160A use the same firmware so they should be able to swap between those. 513 to 513 is for sure a go. Not so sure about the 513 to 515. I thought someone did try that and it didn't work. They do run different firmware so it maybe an issue...
That's great news. Was concerned that the Magnavox units might tie HDD recorded programming to the motherboard of the individual unit like TiVo. (PS thanks for starting the File System Investigation thread.)
post #15922 of 23903
Hi...I just finished recording a movie to a blank Memorex DVD-R with the Mag 515 from a DirectTV HD/DVR and it appears that it recorded fine. I was able to edit the title but it doesn't appear to have finalized and it didn't seem to give me the option to finalize. The owner's manual doesn't seem to give much info on what to do after the editing has finished. I tried the majority of buttons on the remote but they either did nothing or erased the title so that I had to edit the title again.
post #15923 of 23903
The dubbing menu just "advises" that you Finalize for playback on other machines.
You Finalize via the Disc Edit menu, as described here. Press Menu button to see the main menu options.
post #15924 of 23903
That worked!! Thank you so much...I could swear that I tried the "Disc Menu" button on the remote. Is it possible these machines are a little more sensitive than previous because of the hard drive? So, when I finished editing the title, I should be able to just press the "Disc Menu" on remote and finalize the disc or do I have to eject the disc first then insert it before I can finalize it?
post #15925 of 23903
Just press the Disc Edit > Finalize option after dubbing or recording to a DVD if you're all thru editing, etc.
Only "delay" might be for a disc not "loaded" (already in the tray)... it takes a few sec for that to happen and the Finalize option becomes "active" (black instead of grey).
post #15926 of 23903
The "Disc Menu" button on the remote brings up the title list on a DVD. Any time you have the HDD selected, or if you have DVD selected with no disc in the drive that button won't do anything. "Disc Edit" is where you finalize a disc. That is found in the setup menu.
post #15927 of 23903
Thank you Ken!
post #15928 of 23903
Thanks Wajo,
I sold my 2160A last year and wife only uses the Philips (she likes the Philips remote) which only record up to 99 titles. Guess I would buy the 515 to see if the wife will be keeping it.
post #15929 of 23903
Thanks, Vicky.
post #15930 of 23903
Originally Posted by bodhi78 View Post
Here is another very good remote: RCRP05B
http://www.bestbuy.com/site/RCA+-+5-...mote&cp=1&lp=4
Many experienced JP1 users favor this RCA remote.
For an extra $10, minus sales tax, one can buy one of those from eBay instead of Best Buy.
I went to Best Buy to take a closer look, and compared it to a 6 device RCA next to it with bigger buttons for $1 more, RCRN06GR, and finally noticed the RCRP05B had more buttons, including PIP, so brought the RCRP05B home, even though I'd rather had bigger buttons.
And BTW, there is no need to use the SW. Most of the time, setup code will work well enough for you. Again if you read the post on page one, my experience with the URC 8820N is exactly that. Only when you get really into fancy stuff, then the Windows-based program is needed.
By my count, only 16 "DVR" buttons for the 2160A remote matched up. I had to have it "learn" 23 for it to be usable for me. Here's how it's tentatively laid out:
Arranged top to bottom/right to left on RCA
Available via setup code (0675?):
[PRE]RCA RCRP05B NB820 (2160A)
Replay = VREPLAY
SkipFWD = VSKIP
Stop = Stop
Rec = Rec
Menu = Setup
Info = Display
Up = Up
Left = Left
OK = OK
Right = Right
Down = Down
Exit = Return
Manually programmed:
List = Prev |<<
Live = Next >>|
Guide = Title
Day - = HDD
Day + = DVD
A = Input
B = Rec Mode
C = Dubbing
D = Cancel
Ch + = CH +
Ch - = CH -
Fav = Timer Prog
1 = 1
2 = 2
3 = 3
4 = 4
5 = 5
6 = 6
7 = 7
8 = 8
9 = 9
[/PRE]
Above was intended to be easy to view 2 columns monospaced (pasted from work file), but this input system doesn't seem to allow me to do that, and choosing a monospace font didn't work either.
Hopefully I'll be able to learn them myself. I also assigned several "DVR" mode buttons for TV functions, such as PIP, swap and aspect, as well as volume for the Pioneer 1120 that all the sounds come from, so the remote can remain in "DVR" mode most of the time.
I also ordered a new NB820, and then remembered I have an extended warranty, so after the new NB820 arrives I'll check and see if I can get the original replaced without having to send in the recorder along with it.
  Back to Forum: DVD Recorders (Standard Def)
