Originally Posted by excolprof
For the past year I have been recording movies to my 515 HDD at HQ . Then I do front and end cut editing before dubbing to a DVD-R disk. When selecting "dubbing" the dub mode is shown automatically to fit on the DVD. No problem making a good copy. Always wanted to be able to select HSD but could not, therefore RTD was used. Now the mystery--I recorded a movie that edited down to 2:55. I expected to have to use SPP mode to dub to the DVD, BUT, low and behold the "HIGH" mode was highlighted. A mode I could not select before (always grayed out). (The dubbed DVD plays fine.) I didn't do anything different from the normal procedure I followed all these months. How can I make sure I can always select HSD?
A title of 2:55:00 length can only be dubbed to DVD using HIGH (HSD) if that title was recorded to HDD in 3-hr-LP mode.
Re: your question on that note: all RTD's change the default rec mode to the last RTD mode used. Hence, maybe you did an EP RTD last, then did a real-time recording? (Timer rec mode is set in the timer menu.)
You can get HSD only if you make sure your title(s) don't exceed the HSDTimes listed in this help file.
You can check currently selected default rec mode with the RecMode button on remote or, better yet, in the Display menu, bottom right corner on live TV. Help file here.
G
. OTOH their DVDRs...
