Originally Posted by MrNews
Just to revisit a possible 515 OS software issue I detected and posted here about 5-6 weeks ago... I have BOTH of my 515s set to Manual Clock Set ON, and am using the digital Fox Network channel. The unit goes on at 11:59am and 11:59pm, looks for the time signal, and seems to keep absolutely perfect time. Both units' clocks are exactly in sync with my Scientific Atlanta STB clocks.
However, every 7-10 days (approximately), I hear one of the 515's HDD fan running while the unit is off. Sure enough, every single time this happens, the OTHER 515's fan is also running. Powering up each unit for ~30 seconds, and then turning it off, solves the immediate problem, as the fan shuts down.
My theory is that there is some sort of glitch in the 515s OS, and when the designated time set channel is somehow "offline" (no video signal? channel cannot be detected? time signal missing?), the 515 fails to complete the time setting procedure and, although the unit's power remains off, the fan remains on.
It's not a big deal, as I usually catch it within a few hours and shut off both fans, but the fact that it consistently happens with both units simultaneously makes me think that the units are mishandling a time setting signal glitch. Maybe Funai techs could be made aware of this, although it would probably be pretty damn hard to duplicate in a lab.
Again, a good option would be to set Manual Clock Set to OFF, and just reset the clock manually, as needed. Although using the Fox digital channel for time sync seems to work perfectly about 95% of the time. This whole thing may also be another customer affliction from that benificent cable provider, Blight House....
Your topic is close to my quest for a good clock. I have a 2160A and 515H. The 515H is super-quiet and I would not know if turned on. On Sat, Sun & Mon I am up at midnight. The use of Auto would get me a 2.51 hour slow clock from cable NTSC PBS Mon-Fri. The use of manual set to NTSC Fox would get me a 2 year + two hour slow clock on Sat & Sun only. This is true of both units. I have both set to clock set off right now as they are recording stuff.
When doing initial tests the units would only run for two minutes. And bad clock sets are only at midnight, not noon. It makes testing rather a prolonged process.
My clock acuracy from my cable feed has always been 6 seconds slow from various cable fed devices. The Funai units are still (in my opinion) watching for XDS signals. The U.S.A. has a lot of bad PSIP, and it has been recommended to use a manual clock only. I have a VCR that displays the presence of the XDS signal. I get it from my cable feed, but no PSIP or SCTE-127 data that I can detect. My older Mitsu VCR can tape the bad clock and play it back to cause the error (it preserves my analog VBI data).
These are just some observations to ponder.
