Originally Posted by wajo
TV123 might not want to add any ident. yet just in case a return might be reqd ?
There's still an open question whether or not these DVDRs can be returned to a previous FW after a machine takes on the newer/different Model No. TV123 just *might* be the first here who has to answer that question if his problem continues?
IMO, IF the FW can be "reversed" it should take OK. If not, I believe it'll just spit the FW disc out?
I think answering that reversal question is an important element in deciding whether ot not to update, i.e., peace-of-mind if possible to reverse.
You're hurting me. But I'm here for you. Yes, I just performed the 2160A update for the finalize cure. No problem. I had to do the rescan and verify the date. My schedule was wiped, but titles were not harmed. Going to the V2160A was the same. I set it to auto clock to test PBS tonight.
I have no problems. I never did, but just want to help. I'll switch back (up) tomorrow. In summary, you can apply either update at any time but can not go back to the factory firmware. Someone else will have to prove me wrong on that.
