Originally Posted by artwire
Regarding waivers, just saw this from Dec 1
For many years, consumers were able to save some money on their cable bills by simply subscribing to a basic tier of programming. For additional programming, subscribers had to pay for a set-top box provided by the cable company. This worked fine when cable companies transmitted the programming in an analog format. But times, and technology, are changing. Now even the basic tier, like the more expensive ones, is going digital, and that means consumers will have to pay for a box even if they didn't have one before. In response to these events, the Federal Communications Commission proposed a new rule. Public Knowledge applauds the FCC for proposing the rule in response to digital cable technology and protecting subscribers from being hit too hard as a result of the digital transition.
Read More:
http://www.publicknowledge.org/blog/...llo-new-rule-d
FCC ruling (PDF)
http://transition.fcc.gov/Daily_Rele...C-11-153A1.pdf
Read More:
FCC ruling (PDF)
"Furthermore, they contend, encrypting the basic service tier in an all-digital system will eliminate the need for many service appointments because it will allow cable operators to enable and disable cable service remotely by activating and deactivating the encryption capability of set-top boxes and CableCARDs from the headend. In order to remotely activate and deactivate service, cable operators must leave every home connected to the cable plant rather than manually disconnect the cable that runs to a home, which is how many cable operators disconnect service today. If the cable operator is allowed to encrypt every signal, the operator can keep every home connected to the cable plant regardless of whether the home subscribes to cable service. The operator can ensure that only paid subscribers are able to access the service by authorizing and deauthorizing CableCARDs as people subscribe or cancel cable service."
If cable operators are allowed to encrypt everything to prevent real or imagined theft of service, they should be required to provide free CableCARDS for those who can use them and free decrypting tuning adapters (or equivalent) for others who need them. And if truck rolls are eliminated because they can "enable and disable cable service remotely by activating and deactivating ... from the headend", then activating or canceling service should cost no more than (say) $5, with no early termination fees unless subsidized full-featured set-top boxes or DVRs are involved.
