I have read and downloaded your post of instruction on the Mag 515. Question is on autostart. If you record a program does that alter the buffer memory? Let me tell you what I did and maybe you can tell me the correct procedure. I have Dir TV Sat. Recorded last half of 1 hr show on pbs; was watching show for a while and then decided to record show last half hour. thought I could pick up first 30 min. and record from autostart buffer later. the show started at 9pm and i started recording at 9:34. I started record and then saved 26min. of recording. autostart would not go back to 9pm. I could only go back to 9:34. I thought that I had 6 hrs or buffer to go back to. would you please explain the me what i didn't do or what I should have done. Evidently I don't understand the system. I'll admit that my electronic experience is limited but I have always enjoyed electronics! Thanks in advance! videonutwo
post #17761 of 23781
1/13/12 at 7:21am
And we just burned a DVD on our computer, which is much older (and more used) than the DVR.
It would have had to be on all the time for 53+ days to get that many hours.
