AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575
Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 624
post #18691 of 23784
Originally Posted by wajo View Post
Lots of 2160A users have upgraded to SuperFW 727V and I'm sure many of them were original OEM 704's... it's ALL the new 2160A's had in them.
Thanks, wajo. I guess it's safe to assume that someone would have posted if there was a problem with a direct update to 727V. I'll give it a try. Really looking forward to having titling.
post #18692 of 23784
Originally Posted by 234 View Post
FW for same model, you may conduct update/downdate as you want.
But please do not intend to downdate your MDR513H or 515H to H2160MW9's.
It makes your unit unable to update any more.
To recover, you need to send the unit to service center and cost you much dollar.
hi 234...
do you think Funai might provide a ' maintenance ' load firmware for situation where someone mistakenly did this ? i believe that when Funai would receive a unit for this kind of repair, Funai would simply do something like this to make the hardware accept to restore the correct firmware, and then re-load it. this would save a lot of time and money for the consumer, and reduce headaches for Funai.
regards,
Ron G
post #18693 of 23784
Even better, if you get a copy of the latest 2160A firmware and make a CD, you can go back if the 515H features bother you too much. But nobody would do that......
More than once anyhow.
post #18694 of 23784
Originally Posted by rkg22 View Post
hi 234...
regards,
Ron G
Ron, if Funai thought keeping the USA market happy and continuing to produce and enhance the great DVDR product line, you would have good chance of getting your wish. It's only a programming issue, and I thought the same thing when I read of your problem.
But I feel you better take the easy road and accept what cards fate has dealt to you. Really, I don't blame Funai. It's the American consumer that needs help.
post #18695 of 23784
Amazon is having a sale on the 515H. Only $500. The word vampire comes to mind.
post #18696 of 23784
Originally Posted by avsusername View Post
If I have to return it, is there any easy way to back-up what's on the hard drive? It doesn't look like it.
Yes there is a way:
Originally Posted by mrmazda View Post
A clone of the whole HD can be made using a PC if you remove the HD from the Funai for that purpose. The clone will have the exact same files on it if substituted for the original. Also a compressed (or uncompressed) image can be made of the whole HD, which can be saved as a file on a PC and restored to another or the original HD if necessary or desired. One with limited available HD space on their PC might consider the smaller size of the OEM HD in a 513 or 2160A an advantage over the 515 because of this.
For more info click here:
Hard Disk File System investigation for the Magnavox 2080/2160/513/515
post #18697 of 23784
hi 234...
regards,
Ron G
If a Funai USA factory owned service center received a unit with a defective firmware EPROM/EEPROM, they would need a copy of the original firmware in order to reprogram the replacement EPROM/EEPROM. Therefore, your best source for any "original firmware" would be either Funai's Torrance, CA or Groveport, OH service centers. (Refer to address and/or telephone number on back cover of your units User Manual.)
Another source may be one of Funai's Authorized Service Centers, who's name & address is obtainable here: http://funai-corp.com/support/asc.aspx
________________________
PS: Perhaps one of our more knowledgeable electronic specialists has an EPROM/EEPROM reader and might be talked into accepting a challenge to come up with the original FW.
post #18698 of 23784
Interesting about the "72A" firmwares in the newer 513s; wouldn't that be a NEWER firmware (in hex) than the 727 everyone wants to upgrade to? (since hex counts up -- 1,2, .. 7, 8, 9, A, B, C, D, E, F..)
Just concerned the cross-flashing might result in a unit that can't be upgraded in the future... hrrm. (still waiting for my 513 to get delivered to Walmart so I can pick it up, and trying to decide what to do once I get it!)
post #18699 of 23784
I really wouldn't want to downgrade to a 513. I did purchase a 2-year extended warranty also which doesn't go into effect for 2 or 3 weeks, (after the 90 days are over.) I don't know if that would be better if they can repair the 515 instead (or would they?)
I don't think Walmart will repair your 515(probably just exchange it for a new one and if no new ones are available they'd give your money back, at which point you could purchase a 513 which I believe would be cheaper). Another option is to call Funai and get a list of local authorized repair dealers. I did this with a warranted Magnavox and a authorized repair shop was only 5 miles away. I took it to the shop, they determined the DVD drive was bad, ordered it from Funai, installed it and ~3 weeks later called me for pickup, no charge. This is NOT the fastest alternative but you do get your original unit back and working like new
post #18700 of 23784
I just checked the link http://funai-corp.com/support/asc.aspx for an authorized repair center near me, and there is one 15 miles away. If I can find one in the black hole of Jacksonville FL, I'm sure you'll find one close by too.
post #18701 of 23784
Originally Posted by profhat View Post
Yes there is a way:
Sounds complicated
Thanks for the info, sounds like another alternative.
Thanks for the link. That helps.
post #18702 of 23784
Thanks advice, Ron,
We had never received such trouble unit from user, we did not have any solution.
But recently, as I heard of it here, we made solution in our service center.
Now they can recover this problem.
If you involved in it, you may order to Funai service center or Authorized Service Center.
But it costs you some dollar. (I am not sure the cost.)
234
hi 234...
regards,
Ron G
post #18703 of 23784
I can't take credit for that. Stapler provided that link a few posts above.
post #18704 of 23784
Originally Posted by gastrof View Post
I'm a little punchy right now, and there's a commercial on the SuperBowl.
TV shows have been saved by sending some item, dozens or hundreds of them, to network execs. (For ROSWELL, it was small bottles of tabasco sauce.)
How's about we start a "save the recorder" campaign, and send some item to Funai's execs, proving to them how many people out here want the production to continue. (I know part of the problem is availability of certain parts, but there's gotta be alternate sources or solutions.)
Maybe we each send them a photo of our Maggie recorder(s), with the words "save me" in red on the border?
Mini DVDs, with "save the Maggie" written in red with a Sharpie?
No, I haven't had a drop of anything. I'm just getting punchy.
Yeah, I know this could be a whole separate thread...
post #18705 of 23784
513's at Walmart are now $209.98.
post #18706 of 23784
Well, if 10$ is what the need to keep'em coming... so be it.
But any major price increase would probably seal their faith
post #18707 of 23784
hi 234...
regards,
Ron G
Joe, I think that it was me who had this problem (I can't imagine anyone else being so bumbling to make this mistake.) Anyway, the 513 has the 2160A 715 firmware on it, it seems to function normally much as a 513 would, so I am no longer looking for a solution.
post #18708 of 23784
hi 234...
regards,
Ron G
Joe, I think that it was me who had this problem (I can't imagine enyone else being so bumbling to make this mistake.) Anyway, the 513 has the 2160A 715 firmware on it, it seems to function normally much as a 513 would, so I am no longer looking for a solution.
hi jimlely....
based on 234's response, it's possible that Funai would be willing to supply an interim firmware load if you were to request it, although not sure what they might want to charge for it. if one is careful, this kind of thing is not that difficult to accomplish, and could be done ' in the field ', as opposed to shipment of a unit back to Funai. typically, the interim load would be performed just like a normal firmware upgrade, followed by a re-boot, followed by an upgrade to the correct firmware.
were i in your predicament, i would persue it with Funai, just to safeguard your 513's future, if nothing else.
depending on cost, of course, the other solution would be to order up a 513 replacement DVD with companion main PCB for 68 bucks, which would have the correct firmware in it to begin with. this would assume that this is the cheaper of the 2 alternatives.
thanks to 234 for responding to this one...
best regards,
ron g...
post #18709 of 23784
hi jimlely....
best regards,
ron g...
Ron,
The replacement drive and PCB are an interesting suggestion. Here's why:
The burner in my 2160A won't burn DVD+Rs so I'd like to replace the drive anyway. If the "correct" firmware is on this accompanying PCB then I could put the PCB in the 513 and the burner in the 2160A, all for $68. The only downside is the loss of warranty on the 513 (which is new, not a refurb).
Comments are very welcome.
Jim
post #18710 of 23784
Ron,
The burner in my 2160A won't burn DVD+Rs so I'd like to replace the drive anyway. If the "correct" firmware is on this accompanying PCB then I could put the PCB in the 515 and the burner in the 2160A, all for $68. The only downside is the loss of warranty on the 515 (which is new, not a refurb).
I sent an email to parts dept asking if they know about a "recovery" disc or tool. I'll let you know what their response is.
post #18711 of 23784
Wajo,
Thanks. What do you think of the $68 double "fix"?
Jim
post #18712 of 23784
Wajo,
I think you meant to say the double-fix involved your 513, not a 515?
The double-fix doesn't sound good to me since the PCB that comes with the burners is most likely just for burner ops, which is part of the FE FW.
I'm not sure ANY FW is on that small PCB for the burner.
I guess if it were me, I'd order the current burner/PCB for the 2160A and wait to see what develops for the "recovery" tool/disc option for your 513 with the wrong 715 FW?
post #18713 of 23784
Thanks. Yes, I meant the 513.
post #18714 of 23784
best regards,
ron g...
Hi Ron,
Is it likely that the FW really is on this PCB?
Jim
post #18715 of 23784
I can't remember if I prev. recommended a SKIP 987 Mfgrs Process Adjustment as described here?
That test should reject or say "NG" if it can't read a blank +R?
post #18716 of 23784
Hi Ron,
Jim
hi jimlely....
based upon what i've done so far with both my 3576 and my 513 units, i would say that the majority of the smarts, including the firmware, are located on the main pcb that is shipped as a companion with the DVD burner unit.
the small PCB located on the DVD burner unit, itself, is esentially a ' dumb ' interface for the optics, the spindle motor, and the stepper, etc....
the ' motherboard ', appears to be the primary component interfacing the front panel, the tuner electronics, the power supply, etc, however, it does not appear to have much in the way of ' mainstream ' intelligence.
the companion PCB that comes with the DVD burner unit interfaces to the DVD burner unit, the HDD unit, and the motherboard, and possibly even the front panel ( i haven't fully disassembled either of these machines )...
perhaps 234 could confirm that the firmware is resident on the DVD burner's companion PCB. i would bet that it is. i do know that the 513's DVD burner unit, itself, is indeed compatible with my 3576 ( through testing ), and would bet that it's also compatble with the 2160, assuming that it is a good physical fit.
post #18717 of 23784
Is there an easy way to replace the dvd burner in a 515? I was just wondering if it comes down to needing to replace just the dvd burner instead of exchanging the whole machine?
post #18718 of 23784
Hi Ron,
Jim
one more note, here... installing the burner unit by itself into the 2160 will likely NOT make it read DVD+R discs, unless the 2160 is specified that it can indeed do so. the ability to support a given disc technology lies not only with the burner unit hardware itself, but with the electronics and firmware on the companion board.
if the 2160 is supposed to be able to read +R discs, though, then the burner unit should work in concert with the 2160's main PCB.
post #18719 of 23784
hi avsusername...
yes, the burner unit is easily replaced... essentially 4 mounting screws and a couple of ribbon cables. however, Funai only seems to sell the burner unit as an ensemble that includes the companion main PCB...
rgds,
ron g
post #18720 of 23784
Page 9 in 2160A and 513 manuals is identical. Page 40 in 2160A's matches page 41 in 513's exactly. 9 & 41 in 515's matches 513's. IOW, media support in the whole lineage is unchanged.
  Back to Forum: DVD Recorders (Standard Def)
