Originally Posted by
Ken.F
I did the Skip 987 with a TY -R and Sony +R. I'll report back if I get another +RW error.
hi ken...
i get these errors as well on my 3576 Philips machine with -RW discs. usually after they've been used quite a bit. may or may not be important.
HOWEVER... i have 3 Philips 3576 machines and only one of them seems to be tempermental in this regard. the same disc in the 2 other machines never yields an error...
not sure how important the recal stuff would be, since the machines do their stuff using -r and +r media for the cal, and the rw discs are a horse of a different color to begin with...
i've never had the error toward the end of burning, but only at the beginning, like mrmazda stated... this could be a function of where on the disc a blemish might be located... closer to center and you get an early error, closer to edge and you get a later error...
when this error occurs, for me, i do a short manual record ( 30 seconds or so ) to the disc, then erase, then try again... as i recall, this usually maks the thing work.
FWIW, when i load the problematic disc, i can hear the machine hiccuping as it tries to seek, and it usually takes a bit longer for it to lock up and be ready.
this makes me believe that the disc in question may be nearing its end of life cycle or some such thing....
also with the problematic discs, i regularly burn some shows for my sister ( she has a Mag 513 ). We went through a chronic problem with these discs not loading up on her machine and i finally popped the top on the 513 and cleaned the optics, which cured that issue. i'm sure that the problematic discs are still problematic, but cleaning the optics did help her machine load the discs without error...
of course, i ended up cleaning the optics on my 3576 ( the source machine for the burning side ), and that did help things as well...
so maybe you're seeing a combo of ' end-of-life disc ' and slightly tempermental optics ... your machine might be more sensitive to any surface scratches that might be on the discs...
hope this helps..
rgds,
ron g
