I'm seeing version 2 also, but it isn't causing the problems that you're having. I don't know what it means either.
the only time i EVER see the Mag ' formatting ' ( same as philips, by the way ) is when a virgin disc ( right out of the box ) is inserted FIRST into the Mag... i never again see the Mag perform a ' format ' on that disc again, under any circumstances...
This seems important. I get the format every time I insert a blank (erased) disk. I don't know what kind of Mag you're using (model and firmware); that could be a factor, I suppose. Either that, or your discs aren't getting erased properly for some reason.
these things would point, most likely, to an imgburn parameter setting that's not right. but i'll be darned if i know what it is...
It might also be something else, but I'll need to be able to duplicate your results before I can have a chance to figure out what it is. So far, I have not been able to do that.
I'll keep trying to figure this out if you want, but we should probably move the discussion to private messages.
