Originally Posted by
rxheaven
I agree about tha AGC, but this stuff is giving me headaches. I mean, the 2 stations I'm having issues with are the 2 weakest stations. So, hard for me to understand they could be saturated. I mean, I have a heard time understanding how OTHER stations saturating are giving me reception woes with DIFFERENT stations.
Oh well.
I mean, as I stated before, when I have a chance I'll go set my FM trap to OUT, but that'll pretty much be it after.
I don't record anything on FOX (I just watch football live) so not having WFFF on the Mag isn't enough of a deal to continue scratching my head - I'm losing enough hair as it is with aging...
For PBS (WETK), I must admit it pains me a little, as they do have concerts/documentaries that I'd record, but again I'm starting to weight the pros and cons of pursuing this and... I have to move on with life.
hi rx -
your weak stations are NOT saturating anything.... the strong stations are doing the damage and making your weak stations disappear...
ok, the AGC process is essentially an an ANALOG process...
depending upon receiver design, AGC can be affected by stations you are NOT tuned to....
in addition, RF receiver front end circuits, while being broadly tuned circuits, are typically WIDER in bandwidth, than an actual RF frequency you might be tuned to...
a tuner has a receiver front end, a mixer, and an ' IF ' section... no matter what it's used for... turn 'em upside down and they all look the same...
it is in the IF section where receiver ' selectivity ' is essentially accomplished. selectivity is the ability of a receiver to discern a single channel over all others that it is NOT tuned to...
so, for example, lets say your mag is tuned to RF channel 12....
again, depending on receiver design, the RF front end, if it has an active preamplifier, can be completely overloaded by a local strong signal at, say, RF channel 11, or 10, or 9, or 13, etc.... a front end overload causes the receiver to be ' de-sensitized ' , with the result being the lack of ability to bring in the weak channel you are trying to see... this is because the noise floor is being raised so high that the little weak signal drowns in it... orrrrr, the amplifier may be receiving such a strong signal as to throw it out of its linear gain range ( a DC level where the device is designed to function as an amplifier ).
also, again depending upon receiver design, AGC circuits can act the same way. if a strong local signal exists that is not too far away, and the receiver's ' IF ' section is of a relatively wide bandwidth design, that AGC can be affected by the stronger signal, and will reduce the amount of overall sensitivity, again, possibly killing your ability to receive the weaker, more distant signal that you might be tuned to...
i'm assuming you're not a tinkerer at this point, so best thing to do is to order up a set of fixed F-Type attenuators ranging between 1 and 10 dB, eg, 1dB, 3dB, 6dB, and 10dB....
start stacking them at the input to your test mag in sequence as follows....
1 - 1dB only
2 - 3dB only
3 - 1dB + 3dB
4 - 6dB only
5 - 6dB + 1dB
6 - 6dB + 3dB
7 - 10dB only
you get the idea...
gradually add attenuation to see if you can properly affect the level of the aggrigate signals such that your Mag receiver performs as best it can....
i would do this without the antenna preamp, since the antenna preamp is a wideband device that will amplify EVERYTHING, including the noise floor...
preamps can be helpful, but they can also hurt things, raising the noise floor of the aggrigate signal being received...
From ' Receiver 101 ' - if a signal is below the noise floor, you're not going to ' pull it out ' of the floor using a wideband amplifier. you can only ( and then even difficult ) grab a signal out of the noise floor with a TUNED amplifier, since that amplifier serves to reduce that portion of the noise floor being caused by other signals...
the ability to receive a signal, regardless of its strength, is a function of the S/N ratio for the given signal.
you are attempting to do something that is difficult to accomplish without doing some hi-tech stuff... sadly, it is most likely due to the Mag receiver system design, and the only way to make the thing work how you might want it to is going to involve some hi-tech solutions, short of not using the receiver system in the mags...
OTA set top boxes may end up being a better choice, but you'd have to buy or borrow one to test the theory...
ordering up a few cheap attenuators to try the ' snap-train ' attenuation approach is probably the cheapest way to test, to see if you can get a good combination of strong vs weak signals in order to make the mag tuner work for you.
also, i'm sure it was mentioned previously, but it goes without saying that you should be using low loss coax that is at least double shielded, and should probably be of the ' flooded type ' that is used by cable and satellite folks. this type of cable resists moisture contamination...
were i in your situation and serious about what i wanted to do, i'd be using some Andrew FSJ superflex 1/4 inch product for my main long run feeds. stuff like this has a completely solid shield, and it ain't gonna let anything strong get in...
in your ( i believe ) ocean environment, if your feedline is conventional RG-6 and is anything more than a few years old, you can bet it's contaminated.
you should also be inspecting whatever structure you have your antenna mounted on. ANY corrosion or rust near mounting bolts and other connecting metal parts can QUICKLY turn those pieces into diodes, which will generate lots of noise and interference from locally strong signals, regardless of their frequency as it might relate to the channels you are trying to hear.
i worked in a commercial environment for a bit under 30 years and spent many-a-time, trying to help folks who were being bombarded with interference from local adjacent signals. for 90% of the time, the complainers were using grocery store things like RG-59, or RG-6 feedline that was years old and turning green...
of course, they never had any noticable issue until folks like ' local paging carriers ' installed in a building 2 blocks away...
this is just an example...
bottom line is to make sure you maxmize the shielding, and minimize the loss in the cable ( per 100ft )... the loss can vary widely across different cable types.
rgds,
ron g
