Originally Posted by
kenavs
I have a crazy question.
Based on posts that indicate that, in most cases, when a TV is connected to the antenna out, rather than the sharing the antenna feed or even connected to the antenna directly, TVs often indicate a higher signal strength, I assume there is broadband pre-amp between the antenna in and antenna out. I would also assume that this pre-amp feeds the dvdr tuner circuitry.
I believe that rxheaven indicated that his TV reported a stronger signal with a split antenna feed vs using antenna out. I suppose that could be because the pre-amp is noisy, and the TV is reporting S/N ratio.
Is there any chance that the pre-amp is variable gain, and that when strong signals are somehow detected by the gain control circuitry, the gain of the pre-amp is reduced, maybe even to a loss, to avoid overdriving downstream circuitry, for the entire RF spectrum?
That would explain a weaker signal on antenna out and trouble for the tuner when trying to recover the relatively weak signals.
Just a thought.
hi ken....
this is a good piece of input, as i had not thought of the front end preamp that might be inside these tuner modules...
i have not opened up one of the modules, nor have i seen their schematics ( the tuner module is only shown as the ' module ' in the service manuals for these ).. i do know that the module is either made by toshiba, or is at least used in toshiba and other consumer equipment, as it comes up as a replacement for several machines... i have yet to locate any schematic for the device... OT, here, but the reason i was hunting was actually to maybe locate a different ( but pin and functionally compatible ) module that would eliminate the tuner's propensity for lousy black levels...
anyway, i know that someone pointed out way early on ( possibly wajo ) that these things did have some sort of gain stage in the tuner modules.
my guess, however ( and i could certainly be wrong ), is that the powered stage between ant-in and the rest of the mess ( including ant-out ) would more likely be implemented in there as a ' buffer ' stage ( for loading purposes ) and happens to have a bit of gain... well, if 4dB is a correct figure, technically that's a LOT of gain, since 3dB implements power doubling...
adding 3dB to a line level input for an audio device would probably rail an audio power amp running at hi dynamic levels ( alas i love to listen to tunes at as ' live ' level as possible, much to my wife's dismay ) ...
still, the culprit might indeed be something even more rudimentary, like a fixed stage being driven out of linear range, thereby causing loss of weak signals altogether, and weakening of those signals that are stronger, though maybe not affecting them seriously...
in any case, though, any of these possibilities don't really help out with our friend's problem, since fixes to those kinds of things really does represent a higher-tech solution, like tearing into the tuner module to have a look-see, or doing some board level mods to get the thing to maybe handle AGC overload...
in real life, our poor friend needs to borrow a service monitor from a local service shop and have a real look at what's hitting his antenna in ' sprectrum analyzer ' mode, and then address the outside world accordingly...
i feel that his best bet is still to invest in some attenuators and do a trial and error attenuation to see if he can pull the weak stuff out without hurting S/N on the other stronger signals...
oh, by the way folks, the FM trap CAN improve things by first, lowering the noise floor in the FM broadcast section and also reducing strong signal levels in that band that might hit any broadband amp downstream. it might also reduce any locally generated harmonics that might be playing havoc...
of course, these are ALL shots in the dark, so i feel our friend's pain...
rgds,
ron g
