AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575
Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 691
post #20701 of 23768
Well, accoring to J&R this morning, BOTH the 513 and 515 are listed as in stock! It may be your last chance, so get 'em while they're hot!biggrin.gif
post #20702 of 23768
On a positive note: At least AVS is updating and not leaving us "Hanging" like another company I know of smile.gif
post #20703 of 23768
Originally Posted by George55 View Post
Yup, I just did the F7 search and it appears that you are correct.
tnx
George
George, I was joking. Go to the bottom of the page and do a "Search This Thread" for /F7. It crashes everytime for me, but it might be my configuration.
post #20704 of 23768
Apple?
post #20705 of 23768
Originally Posted by JoeKustra View Post
Apple?
post #20706 of 23768
Yup, I got the "Error" then tried it without the "/" just F7.
George
post #20707 of 23768
Can anyone help me on how to utilize my 5.1 home theater system for sound with my Mag 515H?
post #20708 of 23768
Needing a DVR to record and watch four local OTA channels - don't care about anything else. Trying to decide between a Magnavox MDR515H/F7or a CM-7400. Any recommendations?
post #20709 of 23768
Your link is not specific. I have my 515H set for DD and it feeds a Yamaha AVR. I enable all the DSP since the output from HDD stored content is only 2.0 but can be processed. Only a DVD can send 5.1. It's the same audio with HDMI or the digital coax. The audio level is a little higher than other devices, but you may find it normal. I don't playback anything but recorded TV content. You should try PCM to see if it sounds better to you.
post #20710 of 23768
Your link is not specific. I have my 515H set for DD and it feeds a Yamaha AVR. I enable all the DSP since the output from HDD stored content is only 2.0 but can be processed. Only a DVD can send 5.1 and it's the same with HDMI or the digital coax. The audio level is a little higher than other devices, but you may find it normal. I don't playback anything but recorded TV content.
+1. I always use my HTIB with my TV no matter what I'm watching So with my 513 I'm not getting use out of the full system, but it still sounds okay.
post #20711 of 23768
Check post #1 on both threads. Then compare & contrast.
post #20712 of 23768
I have a HTIB which only has 1 HDMI output and 1 digital optical audio input. If I hook up my TV through those 2 inputs/outputs, then I suppose my 515H hooked up via HDMI to my TV will play through the HTIB? I don't see another option, but I'm completely new to this.
post #20713 of 23768
It would depend on the TV, but my Sony sends up to DD5.1 out the optical output. I have CEC and ARC disabled on all devices. It should work.
post #20714 of 23768
Ok, I guess I'll have to wait because I had to order the cables online and can't try it out yet. Hopefully, it will work.
post #20715 of 23768
I just found out that I can not record some HBO programs onto my 2160A.
I normally copy movies from my HBO programs onto my Direct TV DVR and then watch it later. One time I wanted to copy the HBO movie from my DVR onto the 2160A and a message appeared stating that
Your TV does not support this program's content protection, replacing the TV's HDMI cable with component cables will allow you to view the program.
Does anyone know any way to get around this aside from changing HDMI cable to component cable which I don't really want to do due to the quality of the video.
post #20716 of 23768
Check out this help file section on STB Connections... your answer is prob. there. Prob. has toi do with which device is connected to the TV via HDMI or one of the other solutions found by other people there,
post #20717 of 23768
On after thought (I have many of these now that I'm a Senior rolleyes.gif) I'm not clear on how this is a tuner issue. The tuner in my 515 tunes in the channels fine via Direct Access or Channel +/-, it's when I program it to record that things go south. I would think that if I'm able to receive and watch my virtual channel 5.3 via DA or +/- why when I set the timer for record on 5.3 does it record a blank channel?
My guess is that the timer recording channels are set is by looking at the timer schedule channel entry in two parts. If channel 5.3 is in the timer record menu, the recorder reads it as the third subchannel on the physical channel first registered to virtual channel 5. The problem is you have two different physical channels with subchannels on virtual channel 5. KSTP is on physical channel 35 with virtual channels 5.1 and 45.5. KSTC is on physical channel 45 with virtual channels 5.3, 5.4, and 5.45. Since the auto channel preset starts at physical channel 2 and scans up from there, it would have found KSTP on physical channel 35 first. It thinks all 5.x channels are on physical channel 35. We know that physical channel 35 only has two subchannels. When you try to record 5.3 with a timer recording, it looks for the third subchannel on physical channel 35. Since there isn't one, the timer recording is a black screen.
Or I can watch 2.1, but when I set the timer for 2.1 it ends up going to 2.3. Obviously the record programming is not communicating the channel number to the tuner the same way as the Direct Access and the Channel +/- is. The tuner is going to go where it's instructed to go, I'd say it's getting the wrong instructions.
It looks like the same thing is happening there. You get channels 2.1, 2.2, and 2.4 on physical channel 34 but 2.3 is on physical channel 23. Auto channel preset finds physical channel 23 first so timer recordings for virtual channel 2.1 will point to the first subchannel on physical channel 23. The first subchannel carried on physical channel 23 is virtual channel 2.3.
post #20718 of 23768
It's probably not important, but the 2160A doesn't have a component input. But you should try the composite to see if it looks acceptable. When your content is digital it usually looks ok. You will then see if you get letterbox also.
post #20719 of 23768
wajo should put your post up front since this is the fourth time the KSTP/KSTC question has been asked/answered. Someone should buy these stations and donate their transmitters to charity.
post #20720 of 23768
I'm just saying what I think is happening with George's timer recordings. If it was answered before, I missed it.
post #20721 of 23768
Does anyone know how to get the aspect ratio correct with this 515H? On my hdtv, if I set it to 16:9, the 4:3 programs are stretched, but if I have it set to "set by program", 16:9 content is stretched.
post #20722 of 23768
You could probably just unplug the HDMI cable at the DVR box before transferring your programs to the 2160A, then reconnect it when you are finished.
If disconnecting and reconnecting the HDMI cable is inconvenient, give component video a try. Many HD set top boxes will output HD up to 1080i over the Red/Green/Blue component video outputs. You probably wouldn't notice any loss in video quality.
post #20723 of 23768
Try setting the HDMI mode to 480.
post #20724 of 23768
No offence intended. Great explanation. I just remembered that wierd combination from earlier posts. I'm glad I don't live there.
post #20725 of 23768
If I set the HDMI mode to 480 with the TV setting at 16:9, will 4:3 programs look normal with the pillar boxes, and 16:9 look normal as well? Sorry to keep asking, but I don't have HDMI connections yet, just composite until I get the HDMI cables in the mail. I just wanted to know if it's possible to get both aspect ratios to play correctly without having to see either one stretched.
I just got the new HDTV, so it's all new to me.
post #20726 of 23768
The Mag won't stretch 4:3 content, so it must be your TV setting.
I set my Mags for 16:9 Wide, HDMI format at 480p, and watch everything in Wide setting on my TV. WS stuff looks gorgeous but 4:3 stuff gets stretched slightly. Meh!
At least all my 16:9 WS programs record as WS. If I really want to see 4:3 stuff in natural 4:3, I change my TV setting (once in a blue moon and just for another stupid test). smile.gif
The Mag doesn't add an anamorphic flag so 16:9 WS programs recorded on 16:9 Wide won't play back with letterbox bars on a 4:3 TV. even if you set that TV to letterbox.
Here's a help file on aspect ratio.
Go to pg 1 of this thread for an index of other help files.
Edited by wajo - 6/13/12 at 5:47pm
post #20727 of 23768
Hey... We voted to have our channel line-up like that. We figured this would help dissuade all those Canadian "Snow Birds" from wanting to come down here to Minnesota because we have such wonderful winters (and further south is too much of a climate change) Ya You Betcha Sure!!. biggrin.gif
George
post #20728 of 23768
Sounds like it works great for people like you who don't mind 4:3 content stretched smile.gif , but I do not like to see it like that and I watch both kinds of programming regularly, so constantly switching settings would really be a pain. Is there no solution? I can't be the only one who wants to watch content the way it's supposed to be shown.
Everything showed the proper aspect ratio on my old 4:3 TV without me having to keep changing settings.
post #20729 of 23768
If I may offer some help. I set my 2160A/515H at 16:9 (1080p) since my TV is 16:9. The TV is set to show what comes in if it's HD. If it's SD (I have digital cable) then it it will make the 4:3 into 16:9 and my remote has a button to change or override this. If you get your content OTA, all should be happy. Content stored then played by the Mag will come out (HDMI) in letterbox. This is explained in Post #1 and its links. Letterbox is not bad on a 16:9 television. It can be confusing since the raw rf signal will be a nice 16:9 (full pixel on my TV), but a playback of the same content can be letterbox or made wide by the TV.
Not all stations have gone HD yet, so their studio output may be 4:3 (barn doors) since it's really a content issue. Same problem with some commercials.
No, you can't have everything perfect until the world is 100% HD. Someday. Be glad you don't have cable.
post #20730 of 23768
I *think* there are TVs that can switch to whatever format is native to the signal it receives. If yours is not one of those, I don't know of anything else you can do but switch the TV setting yourself based on content.
Your Mag will send 4:3 content as 4:3 no matter what its TV Aspect setting is.
  Back to Forum: DVD Recorders (Standard Def)
