AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575
Magnavox 537, 535, 533, 515, 513, 2160A, 2160, 2080 & Philips 3576, 3575 - Page 707
post #21181 of 23752
8th Generation of Philips/Magnavox HDD/DVD Recorders:
MDR533H/F7, MDR535H/F7, MDR537H/F7 (53x Series)
Three new Mag HDD/DVD recorders have started arriving:
533 ( 320GB ): $244 New, Walmart.
535 ( 500GB ): $248 New, Walmart.
537 (1000GB): $288 New, Walmart.
Operating Manual. The download menu will show "MDR535H" but it's for all three models.
These will be new versions of the 515, as "we" requested in "our" Prime-1 Wish... actually, one I added after a grapevine grabbed me and said it was all over, we might not get ANYTHING more, which prompted the "appeal to Walmart" with the Prime-1 request reiterated from Wish List #1, and the rest is history! You can blame me or thank me for Prime-1, your choice.  mad.gifbiggrin.gif
Each will have a different-sized HDD: 320GB, 500GB, 1TB (1000GB). They'll also have a "different" tuner... ANT IN/OUT connectors are closer together. Previous tuner reached end-of-life (EOL) so Funai had to get a different one. It's still a hybrid (switched) design. Also, HDD title capacity has been increased in the FW from 600 to 900.
Unfortunately, virtually all the errors, omissions and misleads in the manual are still there. Here's a list with page numbers added so newbies know what's still wrong.
Top 12 Things Still Wrong, Misleading or Omitted In the 53x Manual
Jump To:
  1. WRONG: Connection sketch for cable box shows this DVDR behind the box. Still there and still wrong. pg 19.
  2. WRONG: Use your TV tuner (CH- from 2) to find the Initial Setup menu. Fixed in 53x manual. pg 22.
  3. WRONG: Digital channels can't be recovered once deleted. Still wrong, pg 31.
  4. WRONG: PBS is only channel mentioned for auto clock setting. Still wrong. PBS has a time signal but it's almost always WRONG! FOX, CBS & some ABC stations better. pp 28, 32-33.
  5. WRONG: "Unfinalized disc" not playable. Still wrong, pg 67.
  6. WRONG: Overwrite can only be done on unfinalized DVD±RW. Still wrong, pg 52.
  7. OBSCURE: Only one note on important effect of Progressive Scan setting on Mag outputs. Still obscure, still only on pg 15.
  8. MISLEADING: "This unit cannot record images with an aspect ratio of 16:9." Makes a technical point users don't give a shitzu about... it's still misleading and totally unnecessary. Doesn't tell the MOST CRITICAL PART of this highly technical, nuts-&-bolts subject, as described below. MANY people don't buy after reading this ill-advised statement, or they buy then don't know they have to set TV Aspect to "16:9 Wide" to record WS stuff. Both groups then post negative comments quoting this misleading statement from the manual. Other people believe this crap and THEY decide it's not for them. The manual should simply tell readers they can record or copy WS if they set Video > TV Aspect to "16:9 Wide." pg 45.
  9. HALF-TRUTH: Power backup time is 30 sec. (1-hour for 515 & 53x). Both true but only if you don't have Auto Clock ON or set for MANUAL channel. pg 34.
  10. OMITTED: Special Edit/Scene Delete instructions for Front- and End-Cut are undocumented. Still omitted, pp 93-94.
  11. OMITTED: No warning that real-time rec or dub to DVD at different rec mode makes that the default mode. Still omitted.
  12. OMITTED: The Soft Reset procedure for "dead" or "frozen" units. Still omitted but necessary if Funai hasn't fixed the rare but annoying "freeze" issue, which has generated lots of negative reviews because they're the perfect way to shows their anger, and they don't know how easy it is to recover from. No mention in the manual and no reference to avsforum.com for the answer. Still annoying but recoverable if they knew how.
1. WRONG: Connection sketch for cable box wrong for most people. Still wrong. pg 19
For a system with a cable box, the manual shows the box 1st on the coax but that makes this DVDR a slave to the box, i.e., you can only record whatever single channel the box is tuned to and you can't watch one channel while recording another. Ridiculous.
DVDR 1st on the coax, as shown here, takes advantage of this DVDRs amplified and filtered coax passthru/splitter circuit and makes any clear-QAM channels (many users have them) "independently" tunable and recordable. You can also record one channel on this DVDR while watching another channel thru the cable box or TV's independent tuner.
This doesn't change even if ALL your cable channels are scrambled, and you'll only knoiw THAT if you disregard the sketch and put this DVDR 1st on the coax, do an Auto Channel Preset > Cable (Analog/Digital), and see if your DVDR can tune any channels by itself. Worst case: this DVDR can still provide an amplified passthru signal, whether it's on or off, to the cable box if this DVDR is 1st on the coax.
Only if you order PPV/VOD thru the box or if this DVDR interferes with your cableco's Guide or maintenance services should you, instead, use a 2-way bidirectional splitter, with its -3.7dB (min.) signal loss, on the incoming cable, with one output to the cable box and one to this DVDR.
JUST DO NOT MAKE THIS DVDR A SLAVE TO THE BOX BY CONNECTING THE BOX 1ST ON THE COAX AS SHOWN IN THE MANUAL!
Unlike a cable box, the incoming coax from a satellite antenna, which has power/amperage, should not connected to this DVDR at all, as shown here.
Go back to List. ...... Go to main list of help files.
2. WRONG: Use your TV tuner (CH- from 2) to "find" the Initial Setup menu. Fixed in 53x manual. pg 22.
This error alone must account for a high percentage of unit returns. To see the Initial Setup menu, you have to have your TV on the Input to which you connected this DVDR.
Unfortunatelu, the "Before You Start" page in the manual advises you to use your TV tuner to find the Initial Setup menu, as follows: "Press '2' on TV's remote control, then press channel down button repeatedly until you see "Initial Setup" menu." That's WRONG for most people!
Funai apparently assumed that your TV's tuner worked like their oddball, hybrid (switched) tuner in this DVDR. Their tuner ratchets thru the channels AND eventually lands on one of its external inputs (L1, L2, L3, USB).
Your HDTV probably does NOT work that way since most modern TVs have an integrated tuner with only channels in its CH+/- sequence... it never lands on any of its inputs. Your HDTV prob. has a separate button to select one of its INPUTS.
To see the Initial Setup menu, simply select the TV INPUT to which you connected this DVDR... and that can't be the coax connector (ANT IN) since nothing internal on the DVDR goes thru that coax, it's just a signal passthru.
3. WRONG: Digital channels can't be recovered once deleted. Still wrong. pg 31
Once you complete an Auto Channel Preset successfully, both analog and digital channels can be deleted with Manual Channel Preset, and those channels can be added back when desired with the same Manual Preset menu. Deleting and Adding only affect which channels are in CH+/- button memory... even "Deleted" channels can still be tuned or used in a Timer program if entered directly with the number buttons. .
These DVDRs add and delete DIGITAL channels as a group, so you can't delete just one subchannel... in fact, the Manual Channel Preset menu allows entry of just the major channel number. However, one benefit of this is that, once you have a digital channel group in memory, any new subchannels added by the broadcaster or cableco are AUTOMATICALLY added and tunable in the normal CH+/- sequence... you don't need a complete rescan like our HDTVs do... unless they add a new digital channel group, and then you can add it with a Manual Channel Preset (of course, you have to know they added that group first! )
4. WRONG: PBS is only channel mentioned for auto clock setting. . Still wrong. PBS has a time signal but it's almost always WRONG. FOX, CBS & some ABC stations better. pp 28, 32-33,
When the unit is off, Auto-Clock will search the signal coming thru the coax at noon and midnight for ANY channel with a time signal... doesn't have to be PBS. For the 3575/3576 and 2080, that can be ANY analog channel, and for the 2160/2160A/513/515 that can be ANY analog or digital channel. With the Auto Clock > Manual menu, you can set any of the units to search for one SPECIFIC channel, and you can CONFIRM that channel has a good time signal using "The 11:57 Procedure" described here. An Auto Clock > Manual setting prevents an all-channel search and, thereby, reduces the chance of running into a "rogue" signal that can mis-set the time or year or even freeze the machine.
The manual also says this: "If this unit is connected to a cable/satellite box, select the local PBS station on them to set the clock automatically." This DVDR can apparently get a time signal from a cable/sat box ONLY if you connect this DVDR on the coax AFTER the box and MANUALLY set the box to a channel with a good time signal. So, you'd be back to "slave" status as mentioned in item 1 above and a manual process.
5. WRONG: Unfinalized disc not playable. Still wrong. pg 67
You can PLAY or RW-ERASE unfinalized discs in the same brand of Mag or Philips HDD DVDR that created those discs. With Make Recording Compatible (MRC) turned ON, you can PLAY/RECORD/DUB/RW-ERASE/TITLE DELETE in the same brand or the OTHER brand of Mag/Philips HDD DVDR. With MRC ON, and AFTER a 6-sec manual rec/dub or an RW is Erased, ALL disc ops become available, including:
  1. Finalizing ±R/-RW discs and Unfinalizing -RW discs, as described here. If you want to use a Finalized -RW in the other machine, Unfinalize it first in the machine it was created in.
  2. Deleting the Empty Title/Space on DVD±R discs, as described here.
6. WRONG: Overwrite can only be done on unfinalized DVD±RW. Still wrong. pg 52
Manual shows Overwrite only applicable to DVD±RW, but it can also be used on unfinalized DVD±R, as in Deleting the Empty Title described here.
7. OBSCURE: Only one note on important effect of Progressive Scan setting on Mag outputs. Still obscure. pg 15
This note in the manual should be repeated everywhere "Progressive Scan" usage is mentioned in the manual (5 other pages).
First "Connection" page is only place in Mag manual that mentions no output from VIDEO OUT or S-VIDEO OUT jacks when Progressive Scan is ON. Those connection types in any device are NOT designed to handle a Progressive Scan (PS) signal, and these PhilMag DVDRs handle that differently. It's OK to set PS ON in the Philips 3575/3576 since they will send a video signal thru Composite and S-Video outputs... it'll just be auto-converted to interlaced 480i which those connection types CAN handle. On the other hand, the Mags will NOT send ANY signal thru Composite and S-Video outputs with PS ON. Turn it on in those units only if (1) you need to use Component (RGB) connections, (2) you can see a PQ difference between PS on and off, AND (3) you don't need Composite or S-Video output. Leaving PS off allows use of all connections. HDMI has a dedicated "HDMI" button on the remote for selecting and controlling its video formats (480p, 720p, 1080i and 1080p) and an HDMI menu setting for selecting "HDMI Format" (either analog RGB/YPbPr or digital YCbCr).
8. MISLEADING: "This unit cannot record images with an aspect ratio of 16:9". Still misleading. pg 45
Technically true but users couldn't care less... they just want to know if it can record a 16:9 WS program and display it correctly on their HDTVs. It leaves the user hanging without telling the important part: SDTV DVDRs like ours have to record all content in a 4:3 video frame because the DVD std was based on the old NTSC 4:3 std. And an even more important part is: the DVD std ALSO allows a combo of square/non-square pixels, variable horiz. rez, compression and decompression within that 4:3 frame, which allows your HDTV to stretch that frame into a natural WS image.
Explained another way, Wikipedia says this about "anamorphic" widescreen (a term you'll see here a lot) that explains the 4:3-to-16:9 transition perfectly [with my bracketed edits]:
"... anamorphic format camera lenses [our DVDRs] compress the image horizontally so that it fits a standard [4:3] frame, and anamorphic projection lenses [our HDTVs] restore the image and spread it over the wide screen."
It IS a technical subject, so if you really need more technical details, here's a nice Wikipedia entry on Widescreen where you can read a little about why SDTV DVDRs record all content "as 4:3."
If you're a dimwit like me, all this technical crap probably makes your head hurt!? Even that last Wiki link above has to admit at top: "This article may be confusing or unclear to readers"... duh, ya think!? To make your head feel better, just think like I do: There's some "electronic voodoo" going on in our 4:3 frames that makes digital WS programs look beeeeauuutiful! Just do as I do: let the technicians argue this among themselves while we pragmatists revel in our wonderful widescreen world!
More info on WS related specifically to these DVDRs is here.
9. HALF-TRUTH: Power backup time is 30 sec (1 hour for 515 & 53x). Both true but only if you don't have Auto Clock ON or set for MANUAL channel. pg 34.
True ONLY IF Auto Clock is set to OFF. When set to AUTO or MANUAL (even if you have no confirmed time signal), 30-sec power backup extends to 2-3 min. and 1-hour extends to at least 2 hours and sometimes an unbelievable time. With a 515, rmacdona got 60 hours! A power loss for MORE than those time periods loses the clock time and all timer rec programs (cuz they're tied to the clock). However, HDD titles, channel memory, and all menu settings remain.
Weird note: During a total power loss here, my 3575's and 2160 maintained all settings, incl. clock and timer rec, for 12 hours! My units had been set for Auto Clock > Manual > FOX analog channel in my cable TV feed for 9 months.
10. OMITTED: Special Edit/Scene Delete instructions for Front- and End-Cut are undocumented. Still omitted. pp 93-94
The manual describes how to remove a commercial inside a title... a Mid-Cut. However, there are NO instructions for making Front- and End-Cuts, both of which are needed for virtually every title you care about. Those cuts can only be done accurately and reliably by using a specific play-mode button to set Start and End points, as described here.
11. OMITTED: No warning that a real-time rec or dub to DVD at different rec mode makes that the default mode. Still omitted.
Users need some notation or warning that a real-time record or dub at a rec mode different than their current Default changes their Default to the mode selected for the rec or dub to DVD. This is true for a manual recording, manual timed recording or real-time dub (RTD).
12. OMITTED: The Reset procedure for "dead" or "frozen" units. Nowhere to be found. Oh wait, it's only in a help file in this thread.
The manual doesn't mention the Soft Reset procedure that can bring "dead" or "frozen" units back to life.
In another forum, a gearhead found a reset button INSIDE his unit and posted that "all anyone has to do is open the case and press that button with the unit plugged in." eek.gif
That recommendation excites the gearheads among us but is a potential "zap-trap" for the vast majority of your users. Most are ex-VCR jockeys and they're not even CLOSE to "gearhead-level" who can safely play around inside a multi-board DVDR case. People need to know that the simple, non-invasive Soft Reset has brought frozen units back to life, without cracking the case! Funai, PLEASE ,mention the Soft Reset in your manuals and in advice from your Customer Support Reps! Who knows, you might prevent some returns with the story: "I don't know what happened. All of a sudden, all the electronics just melted!" biggrin.gif
Edited by wajo - 4/1/13 at 9:32am
post #21182 of 23752
Originally Posted by wajo View Post
Then, in later sections, they repeat the Satellite-connection-to-ANT-IN theme, like in scanning for channels. An RF connection might only apply to a sat system with local antenna? (I'm not sure how a sat system works with DVDR RF, if at all, but if their main coax has LNB/sat-system voltage in it, it might not be good for the DVDR?)
A satellite box like the VIP722K has a fixed rf output on channel 3 or 4 (not sure if both) so that would be the only analog channel found on a scan. I think the VIP211K also sends out all satellite channels on vsb rf. My sister has DirectTV, so I'm speculating. I know she has old analog TVs connected to the dish. Yes, the satellite STB must go to the sat box first.
No HD. That's sad.
Edited by JoeKustra - 7/29/12 at 2:49pm
post #21183 of 23752
The 533/535/537 Manual is actually ready for download this time.
I checked the link & it still D/Led the 513 manual. Did I check the wrong thing?
post #21184 of 23752
I re-confirmed that the link above does open the Download page for the 533 manual. You have to click on the word "Download" at right, then a pop-up download message should show MDR533H_EN_OM.pdf in the bold text.
Does the manual you downloaded via the link say MDR513 on the cover?
Edited by wajo - 7/29/12 at 3:38pm
post #21185 of 23752
For some reason it still downloaded the 513 manual when I clicked on the link.
I tried right clicking & save as.. & it got the 533 manual.
Not sure why it would work that way.
post #21186 of 23752
Cookies?
In working on an AVS Retro skin, I noticed that IE was "tenacious" in holding onto cookie info and using it on pages you're browsing. I'd have to logout, close IE, open IE, log back in for each change to the stylesheet (many of those). FF, Chrome and Opera didn't exhibit that same "feature"... style changes would appear immediately w/o logging in or out
post #21187 of 23752
Cookies?
I'm using FF.
Did quick check of new manual & it still lists the exact same brands & speeds for recommended DVDs.
The only ones I can use are Sony +RWs or -RWs now. Sony -RWs are not even listed.
And to be fair I have never found a JVC disk.
Hopefully they will upgrade firmware so it will accept newer disks.
Have maybe recorded 1 non RW disk since I bought my 3575 so can't say which -R or +R disks my unit will use.
post #21188 of 23752
I'm using FF.
I don't remember your exact DVD problem but if it involves moving discs between your computer and DVDR, I'd look to your computer. There is virtually no way for you to click on a download link that goes directly to a 533 document and ending up with a 513 document unless your computer "intervened" somehow???
I've been left-clicking that link and downloading regularly since you reported your result and always get the 533 manual, also using FF.
Edited by wajo - 7/29/12 at 4:54pm
post #21189 of 23752
I've been clicking that link and downloading regularly since you reported your result and always get the 533 manual, also using FF.
I closed FF & restarted it, then tried the link again & it worked fine this time.
Orig problem was finding blank RWs that the 3575 would recognize.
Had to open up unit & clean the lens.
post #21190 of 23752
Did I already ask if you installed the lone FW update for the 3575, which is for a disc-reading problem, I believe?
post #21191 of 23752
Yes you did.
That was installed quite a while ago.
Is it possible that it would need to be re-installed?
post #21192 of 23752
Yes you did.
I don't think so, as long as your update session ended with "Upload (or Update) successful" or similar.
Only other thing is a SKIP 987 Mfgr's Process Adjustment, for which you need a -R and +R disc.
post #21193 of 23752
When I get a chance I'll double check the firmware version # to make sure.
Already did the skip 987 process when I had original posted problems.
post #21194 of 23752
The 533/535/537 (53x Series) Manual is now available
These are new versions of the 515, as requested in "our" Prime-1 Wish... actually, one I added at the last minute when it appeared we might not get ANYTHING more... you can blame me or thank me, your choice. mad.gifbiggrin.gif
HDD title capacity has been increased to 900 from 600.
Unfortunately, virtually all the errors, omissions and misleads in the manual are still there. Here's a list with page locations added so you know what's fixed and what's still wrong.
TOP 12 THINGS WRONG, MISLEADING OR OMITTED IN THE MANUAL
Seems Funai are doing everything possible to mislead and confuse future "53x Series" buyers, which will ultimately lead to a large supply of returns and "Refurbished" systems at Amazon, J&R and other vendors.
On second thought.........
post #21195 of 23752
OK, I've read through parts of this thread as well as others relating to a freeze up of a 515, but didn't seem to see the exact scenario that just happened to one of mine.
I use it 99.9% of the time to record and play back DTV stations. It's connected to my cable (no cable box) and I use HDMI to output to my Samsung plasma tv. I installed the upgrade for the 515 when it was first discussed on these boards.
I've been using the machine for a while, quite extensively, w/o any issues, until today.
Last night I did an unusual thing - I switched to analog to check in on ESPN while I was watching recorded shows. So when I went to sleep, I left it on that analog station, but turned off the unit and tv.
This morning the unit powered up but the display just showed the analog station # from last night - no picture out to the tv. I unplugged it, but I see I didn't wait long enough to restart it based on the info on the board, but when I plugged it back in, I get the time display, not a blank screen like most others report as part of their problem.
The unit will not respond to the remote or the power button on the unit - it just keeps showing the time.
I'm now letting it power down for the 2.5 hours recommended here, but I am concerned since I had no power surge and the display is not blank, as most problems reported seem to have.
I guess if this doesn't work I'll have to pull the hard drive and plunk it into another of my units because I have a ton of stuff on it I want to watch.
post #21196 of 23752
Don't pull the HDD, just do a Soft Reset as described here.
There's a FW Update for the freeze problem you might want to consider. It's DTV-S Version 0x2C here. Several people with same problem have installed it with good results.
post #21197 of 23752
I read about that. Don't quite understand how to install it when the unit won't do anything but display the time.
I'm hoping it was leaving it on the analog station so when it powered on this morning that was different from any other time since I so rarely ever use the analog tuner.
post #21198 of 23752
Do the reset first. To watch analog I use my TV. I haven't done that in a year or so.
post #21199 of 23752
Did the reset after waiting 3 hours after pulling the plug and everything is back to normal.
Thanks for all the help!
post #21200 of 23752
That's why they call it the analog freeze. Before the firmware fix, I religiously made sure the unit was turned off on a digital channel only. The fix works like a champ.
post #21201 of 23752
I compared the 515 manual with the 533 some differences I found.
1. Of course Hardrive space.
2. The antenna connectors are close together on the 533
3. The 533 does not have MP3 -DVD playback capability
4 The virtual Surround stereo option is not available on the 533
5. A Big Copyright Protection Law disclaimer found with the 533. - Not sure if this is a physical change from the 515
6. The English grammar appears to be easier to read in the 533 manual
Are there other differences that I did not find?
Edited by DonB2 - 7/31/12 at 7:13am
post #21202 of 23752
The SATA-based units play MP3 on DVD, as first reported here. ... unless the 53x are "odd ducks" all of a sudden. The 53x manual is first to specifically note that it can't play MP3 from DVD. All other SATA units don't mention MP3 in Unplayable Discs section, but do show MP3 playable from CD-R/RW in the Playable files section (pg 64, 65, 66 in 2160A/513/515 manuals). 53x manual REMOVES that "Playable on CD-R/RW" notation that all other SATA manuals have. MP3 playback from CD AND DVD needs to be checked when these new units arrive. Click the link above for tips on what that user did to get playable MP3 on DVD.
Surround sound notations are same as in other units, starting with the 3575.
The ANT IN/OUT connectors being closer together indicates a "different" tuner. Old supplier's tuners hit EOL.
Edited by wajo - 7/31/12 at 8:38am
post #21203 of 23752
Still needs the TV/DTV button. A new tuner may have helped a few people here. Maybe next year.
post #21204 of 23752
...The ANT IN/OUT connectors being closer together indicates a "different" tuner. Old supplier's tuners hit EOL.
Wajo-
Could you explain what EOL means?
"Old supplier's tuners hit EOL."
post #21205 of 23752
Originally Posted by gastrof View Post
Wajo-
End Of Life
post #21206 of 23752
I assume end of life.
post #21207 of 23752
Wajo-
End of Life, when a mfgr decides not to build anymore. Good explanation here.
post #21208 of 23752
would be interesting to see if the actual board footprint is the same or not... if so, this new tuner might represent a retrofit advantage for the 51x machines...
just a thought...
rgds,
ron g
post #21209 of 23752
In case someone runs into the following problem : NO FRONT PANEL DISPLAY - NO POWER ON - NO RESPONSE - Resets don't work.
Model: MDR515 - 8 months old
Did the checks and recommendations several times (unplug for long time /plug, Soft reset, etc.). No change.
Opened cover and check PS fuse. Good.
Checked PS voltages. Bad. Something loading supply.
Disconnected one load at a time. (Hard drive - nope, Circuit boards-nope)
Carefully disconnect two flat ribbons for DVD. Bingo. Unit powered up. Everything looked good (less DVD smile.gif)
Checked DVD drive motor, optics, etc. for short. Nothing. No jammed mechanisms Figured something on CCA was bad.
Decided just for the heck of it to reconnect the drive one ribbon at at time and power on after each.
What do you know powered up and worked perfectly
Put back together and everything works
Will monitor. Might be a sign of a bigger or pending permanent failure.
post #21210 of 23752
Perhaps a poor connection with the connector that demate and mate cured? Check the connector for signs of corrosion.
Edited by glangford - 7/31/12 at 1:37pm
  Back to Forum: DVD Recorders (Standard Def)
