Originally Posted by Kelson
Just keeping it real. Roll your eyes all you want, but electronics do eventually fail. And todays cut-rate electronics built to walmart price-points will fail a lot sooner than one would like. DVD media is universally playable on a multitude of equipment from different vendors. Storing program material on a fleet of proprietary format HDD's that can only be played on a single brand (model?) of throw-away recorder is more like a graveyard than an archive. Your strategy is fundamentally flawed.
But if that's what you want to do, good luck and use SATA drives -- so they can at least be reformatted and recycled into a PC disk farm.
I'll worry about it when I can no longer do a rebuild.
There is software that can read these drives. The format used is Linux, and guess what, its free.
