Originally Posted by wajo
Here's a better example of an IDE-USB adapter.
And here's just one of many samples on A-B end converters, F/F, M/F, etc.
One thing I forgot to mention is the mental "switching" needed to understand how this might work... we'd be reversing the normal "descriptive usage" of these adapters where they tout its ability to convert an external IDE/SATA HDD for connection to a USB port in a computer, we'd be reversing that scenario by connecting our internal PCB cable to an external USB HDD thru the adapter and USB end-converter.
Go for it.
I wish you luck, remember usb is much slower than esata.USB interface: 480Mbps USB 2.0 high speed (USB 1.1 compatible)
eSATA interface: 3.0Gb/s SATA II high speed
USB2.0 to SATA I,II = USB 2.0 port rated at 60MB/s
eSATA to SATA I = SATA I port rated at up to 150MB/s
eSATA to SATA II = SATA II port rated at up to 300MB/s
My question what do you gain and what do you save by going usb? (if at all possible)
