Originally Posted by artwire
Guess I do need a different screwdriver - #2 posidrive. if people were using phillips head, maybe that's why the 'screws' seem difficult to remove( in other accounts) ?
I assume our machines are similar, but will the difference between posidrive and phillips screws be obvious?
Yes, there is a visible difference between phillips and pozidrive. If you look closely at cross pattern recess in the screw heads, and also the screwdrivers/bits themselves, you will see the small but noticeable differences between a phillips and a pozidrive. But for as small as it looks, having a pozidrive screwdriver or pozidrive "bit", for those who may be using a screwdriver that uses bit inserts. Can make a big difference in how easy it is to remove a pozidrive screw, without doing any damage to the screw head.
And, it works the other way around also. In that using a pozidrive screwdriver/bit, on a phillips screw. It also will not fit the phillips screw properly, and will more than likely damage the phillips screw head.
http://en.wikipedia.org/wiki/Pozidriv
s.
