Originally Posted by dare2be
Thanks wajo for the welcome (a couple pages back)...I need to show up here more often as this thread is very active...
When I initially set up my 3576 with just coax in/out to tv, I could see the live broadcast but not the menu overlays (like when pressing setup or info) nor could I play back HDD recordings thru the coax. Is that a hard fast limitation, or is there a way to send all output thru the coax?
Nothing internal from the 3576 can be seen thru the coax... it's just a passthru of the raw incoming signal.
You need to connect a line output from the 3576 to a line input on the TV (Composite, S-Video, Component and/or HDMI), as shown in the appropriate sketch in this help file.
The first three connection types need L/R audio as well as the video cable, as shown and described in the linked help file.
For future ref. to help files, click #1 in my signature.
