Originally Posted by Stettin
Hi all. I've decided to upgrade my main PC and put my old parts into the HTPC after realizing how much I was spending. This changes a few things for me. I'll be using an ATX board
EVGA 750i FTW, Core2Duo E8400, 4GB DDR2-800 ram, LiteOn DVD-RW (re-used parts)
1.5TB Samsung 5400RPM
LiteOn Blu-Ray ROM
I thought I might be able to use my old power supply, but looking at my MB I need one with an 8Pin EATX12v connector. Also, I'm thinking about getting a case since I'm having to buy a power supply anyway.
Can anyone recommend a NO FRILLS ATX HTPC case that a stock Intel Heatsink/fan will fit in? I don't need an IR receiver or remote. I already have those.
LiteOn Blu-Ray ROM
A 4-pin ATX 12V CPU power connector is enough for E8400. A 8-pin is only for an older, power-hungry quad core CPU (e.g. QX6800, 130W, QX9770, 136W etc.).
The stock Intel CPU cooler fits *every* HTPC case.
