I have a question. I'm getting ready to pull the trigger on a HTPC. An important feature I'll be looking for is the ability to connect this to 2 video outputs. One will be my projector setup and the other will run to my family room. I assume the setup will be similar to have dual displays on a regular computer. What would be the most effective way of doing this? HDMI connection to the projection and DVI to my Plasma or vise versa? The video out seems fairly straight forward, I'm trying to wrap my mind around the audio. I figured whichever is HDMI I could utilize the audio through that and connect the DVI for video and optical for the audio on the second? Will this work? Hopefully I've made clear the thoughts in my head. I'm not going to have a very complicated setup, just want to use the HTPC in 2 rooms. Any help, or direction is appreciated.
When it comes down to brass tacks this PC will end up being a simple file server for music and will play (up to 1080p) .mkv's on the theater and my family room plasma. I need the system to fully support the proper audio within the .mkv for full surround. Would a low end PC achieve this or should I go higher? I don't mind spending money where I need to but see no reason to overspend either.
