I have the following build:
CPU: Core i3 530 2.93GHz LGA1156,
CPU Cooler: Cooler Master (Geminii S) RR-CCH-PBU1-GP,
Motherboard: ASRock H55M Pro LGA1156 Intel H55 chipset microATX,
Memory: G.SKILL F3-12800CL9D-4GBNQ DDR3-1600 2 x 2GB Kit,
Graphics Card (ATI): HIS H567Q512 Radeon HD 5670 GDDR5 512MB,
HDD: Western Digital WD6400AAKS 640GB SATA 3.0Gbps,
PSU: Corsair VX450W CMPSU-450VX 450W,
Case: Antec Fusion Remote Black microATX, with LCD/IR receiver/remote.
I installed windows 7 last night and upon the first login it took forever at the windows icon screen and then windows explorer crashed. I tried starting in safe mode and get the same crash after it takes 5 minutes to try to load windows. The error code says:InPageCoFire c000009c
Any ideas on this? After some google searches i think it may have to do with the video card not having a driver, but never seen windows fresh install crash afte rinstalling like this. Any help would be appreciated. I am using Ubuntu to reformat the drive and changing BIOS to use onboard video before trying to reinstall again to see if i can get windows up and running so i can register it and then download needed drivers. Is there a way to install needed drivers during windows instillation?
My Norco case is in a rack in the basement and I could fairly easily hear the stock fans on a decent chunk of the first floor of the house. The extra money spent on the fan board that allows you to use 120mm fans is money very well spent.
