Hi All,
Hopefully somebody can help me with my dual screen setup.
First of all, I have a Sapphire 5670 with HDMI/DVI/DisplayPort.
I have a my main screen (Panny 50" plasma) and a newly purchased Acer T230H 23" touchscreen montior. The goal is to watch Movies and TV on the big screen (while the touchscreen is OFF) and use the touchscreen (periodically) to navigate through my flac library and play music (when the plasma is OFF). I currently have my system setup with the HDMI from the 5670 to my AVR and the DVI from the 5670 to my touchscreen. The HDMI output of the AVR goes to the plasma. In the display properties, I have the option of using either monitor as the "primary" output, duplicate both displays or extended the displays. Currently, I have the two duplicated, but the audio shuts off when I turn off the plasma (with the touchscreen ON) while listening to music. The other concern with using a duplicate display setup is that both of my monitors have different native resolutions (Panny is 720 while the Acer is 1080). Ideally, I'd like to have the ability to turn off the plasma, have the Acer output at its native 1080 resolution and have seamless audible playback through my HT. Has anyone had any experience with a similar setup that might be able to extend a helping hand?
Thanks in advance.
Thanks in advance.
