Originally Posted by Andras
In Post #14144
# Motherboard: GIGABYTE GA-880GA-UD3H AM3 AMD 880G/SB850 chipset ATX, $98.
# Memory: G.SKILL F3-12800CL9D-2GBNQ DDR3-1600 2 x 1GB Kit, $65.
The above seem incompatible, since the motherboard can only handle DDR3 1866(OC)/1333/1066. G.SKILL F3-10666CL8D-4GBHK seems to be a good choice for that motherboard.
In Post #14144
Yup, memory clock is a bit confusing.
- A memory module rated, for example, 1600MHz (effective) is able to run stably at any clock <= 1600MHz.
- The current Athlon/Phenom processors supports up to DDR3-1333.
So selecting DDR3-1600 is not bad in that
- The price difference between DDR3-1600 and DDR3-1333 is little.
- DDR3-1600 has overhead for moderate overclocking.
- There are dozens of memory modules DDR3-1600 that work with GA-880GA-UD3H. From Qualified Vendors List (QVL) for GA-880GMA-UD2H
Memory modules listed below are for reference only. Due to massive memory models on the market, we can only verify some of them.
DDR3-1600
AX3U1600XB1G7-EF
etc.
DDR3-1600
AX3U1600XB1G7-EF
etc.
