i'm confused,on the bottom where it says,wont that allow me to hear sound from tv if using that s/pdif adaptor to the sound card?
The NVIDIA® GeForce® 8 Series graphics card supports HDMI with audio integration solution. With a DVI-to-HDMI adapter and an extra signal cord through the bracket, audio source from sound card(S/PDIF) can be integrated into HDMI interface by simply plugging the cord into the pinhead located on graphics card. Only 1 single HDMI cable is required while streaming audio/video data to flat-panel display devices, such as Plasma/LCD TVs, or projector
If MSI NX8600GT-T2D512E OC supports HDMI audio, then you will need a special DVI-HDMI dongle to extract audio from the DVI port (the blue dongle as seen in the MSI site). Unfortunately the model at Newegg.com does not come with it. "HDMI with Audio Integration Solution (Optional)" means that some retail version of the model may not support HDMI audio.
could i use the dvi to hdmi adaptor from monoprice or does it have to be the dvi to hdmi dongle?
For ATI Radeon HD series cards, you need ATI's proprietary dongle. For GeForce 8-series, I don't know ... you may be able to get an answer from the MSI tech support.
I'm working on designing my first HTPC. This thread has been a great help! Thought i would list my parts list here to check for any concerns before i pull the trigger:
Case: Omaura TF11 w/IR option
MB: GIGABYTE GA-EP35-DS4 LGA 775 Intel P35 ATX
CPU: Intel Core 2 Duo E6750 Conroe 2.66GHz LGA 775 65W
Video: GIGABYTE GV-RX387512H Radeon HD 3870 512MB 256-bit GDDR3
Memory: A-DATA 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
PS: CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W
HD: SAMSUNG SpinPoint T Series HD501LJ 500GB 7200 RPM SATA 3.0Gb/s
Cooling: ZEROtherm BTF90 92mm Silent UFO
OS: Vista
OS: Vista
Any feedback would be appreciated! Thanks.
Check the new Enermax PSU. Right now it will cost $50 more than Corsair though.
My current setup is a Samsung LNT 4061f (supports 1080p) with a ReplayTV and standard DVD player; there are no speakers/receiver/etc. I'd like to wrap the PVR and DVD player functionality into a HTPC and I have no short-term plans to add a receiver or external speakers.
Some general questions:
1) To reduce power consumption, is it possible to configure an HTPC such that it will, for example, suspend to S3 and then wake itself up to record a show? What hardware/software is required?
2) My HDTV supports both DVI and HDMI. If I plan to watch only standard DVDs and non-Encrypted HD TV, is there a difference between these two connects?
3) To watch standard DVDs via HTPC, is there any particular hardware required beyond a simple DVD/RW? I understand that people will upsample DVDs, but it's unclear to me whether that's done on-the-fly while viewing? Or, is the DVD ripped, upsampled, and then viewed?
4) In what scenarios is hardware HD encoding/decoding required? I'm considering the Low-End II system described earlier in this thread and that's the one limitation mentioned.
5) Since my TV supports 1080p, but most current HDTV is only 720p or 1080i, is upsampling possible? If yes, is it done on-the-fly? Or, is post-processing required?
Scythe Mini Ninja - 32.00
AMD Phenom 9600 Black Edition - 220.00
Gigabyte GA-MA78GM-S2H - 86.00
Crucial Ballistix PC2-6400 4GB 2X2GB - 99.99
Samsung Spinpoint T Series HD501LJ 500GB - 96.00
BLK MEDIA CENTER CASE ANTEC FUSION 430 - 157.00
Harmony 880 Advanced Universal Remote - 142.00
LG Electronics GGC-H20L LightScribe Blu-ray/HD DVD Combo Drive - 168.00
Total 1000.99 before taxes. All prices CAD.
What do you guys think?
The parts I'm not sure about are the CPU (would rather get the 9150e), the ram (2gb should be ok, but the price difference is negligeable), the remote and the case.
If you know of any cheaper alternatives without much performance difference please reply.
That machine will be primarily used for watching HD satellite feed (didn't choose the hd sat tuner card yet).
Thanks!!!
Will the Harmony 880 Advanced Universal Remote work with most TV/HD sat tuner cards in this configuration?
Thanks!!!
Where are you getting the combo drive for $168.00?
MicroFly Ultra Micro (depth limitation in entertaiment center. $79
Intel Pentium Dual core E2200 2.2GHz. $79
EVGA e-7100/630i w/DVI out HDCP compliant $69
Corsair 2 x 1 GB DDR2-800. $29
WD SATA 250GB $69
I was planning to use the onboard graphics and connect DVI to HDMI on a Sony V3000 1080p LCD. Suggestions?
In my other HTPC I have an ATI Radeon HD2400 and Digital Mystique Dolby Digital Sound card. I could use these products if the integrated graphic and sound aren't performing well.
I would like to add a blu-ray drive in the near future. Would this system handle CyberLink Ultra playing bluray?
This thread is a great resource, thanks!
1) Yes, for example under VMC. What you need is the support by the motherboard.
2) Basically DVI = HDMI in video. There is no difference.
3) Upsampling is done automatically by graphics card.
4) HD decoding is always necessary to play back HD contents encoded in MPEG-2/VC-1/H.264 or whatever format (e.g. BD/HD DVD movies). HD encoding (actually transcoding) will happen, for example, when you want to save a MPEG-2 content in another format, say H.264.
5) Your question is a bit unclear. Upsampling is part of post-processing and done by the grahics card (on-the-fly). There should be no problem.
Just did a minor rebuild and got some nice results.
Previously I had a Biostar 7050 with a AMD X2 4000+ @ 2.6 Ghz. Most video would run but had a slight stutter which was just barely noticeable. Just upgraded to Gigabyte GA-MA78GM-S2H and AMD X2 5000+ @ 3.0ghz. Everything runs much more smoothly and quite cool considering the boost. Seeing as that mobo+chip and 2gb of RAM is right around $220 from newegg it would be hard to suggest anything else at this point.
WD SATA 250GB $69
Coaxial S/PDIF is in only. So you need to use the optical port. The onboad video is not good for PowerDVD. You will need a discrete graphics eventually.
Hi i am just curious which onboard sound would be best suited for decoding DTS-MA. I am looking at the Realtek 885, 888, and 889A. Are all of these sufficient, or will 1 do a better job than another?
I will be using the analog outputs to my Onkyo 805.
Am i better off just scrapping the onboard sound altogether and getting a soundcard?
AMD 5000+ Black Edition unlocked - 85.00
Crucial Ballistix PC2-6400 2GB 2X1GB - 64.99
Microsoft remote with ir receiver - 22.00
Digiwave 103g sat tuner - 59.00
Total 860.00 including shipping/insurance/taxes. All prices CAD.
I decided to dump the harmony 880 because I already have the harmony 620.
But couldn't resist the microsoft remote as it was only 22$ and recommended here.
As stated previously I switched the 9600 phenom for a 5000+.
Saved 135$ and it should be powerful enough.
Went down from 4GB ram to 2GB ram mainly because it has been said that 2gb is enough. I still have mixed feelings about that because the digiwave 103g comes with a remote compatible with MyTheater and others, so maybe I should have kept the 4GB and forget the microsoft remote. Oh well...
If you have comments/suggestions about that just reply as I still have a day or two to change my mind.
One thing for sure: this machine will look good in my living room
Decoding is done by a software player like PowerDVD. If you use analog sound, ALC889A is the best among them, but you'd better buy a sound card.
With the price of the 5000+ BE being the same as the 5400+ non BE (OEM edition), what benefit is the 5000+ BE for me?
AFAIK, the BE only adds overclockability. Would I need to overclock this processor if combined with the new accelleration mobos (such as the 8200)?
I do not plan on overclocking unless I have to do so, so I currently plan on getter the higher clocked 5400+ (since neither comes with a HSF).
Is this wise, or am I missing something vital about the black editions?
Nope, you have it - unlocked multiplier (overclocking) is the big feature of the black editions. And, they don't come with a heatsink / cooler so you'd have to spend additional for that. I would agree that the 5400+ makes more sense in your case.
