Originally Posted by MrMcCrackin
Moneual 312
i have tried 2 different sets of tripple 40mm fans (noisy) and taking the 2nd HDD out and removing the PSU from the case and adding a 80mm fan
i tired blowing air into the case and sucking air out of the case, by far sucking air out works the best.
im going to take a look at the stock cooler this morning and reseat it to see if that helps
Moneual 312
I am using 3 silenX 40 mm fans sucking air out of a 320 case with i3530 and stock cpu cooler, radeon 5570, 4 GB RAM, 430W Enermax Liberty PSU and the idle temp hovers at around 46 C.
The distance between the surface of the mb PCB and the bottom of the bracket is ~77mm. So a cooler of hight 70mm should fit the case.
