AVS › AVS Forum › Video Components › Home Theater Computers › Guide to Building a HTPC, Workstation and Server
Guide to Building a HTPC, Workstation and Server - Page 62
post #1831 of 18891
Fratar
So you have two separate problems:
1. S/PDIF does not work when the internal S/PDIF is connected to your 9800 card.
2. HDCP error when playing back BD with 9800 and PowerDVD
As for 1, you need to select the correct sound playback device in Windows and you have to use a proper DVI-to-HDMI adapter (otherwise audio won't pass through DVI). I noticed that not every 9800 GTX model comes with a DVI-HDMI dongle. In this case you need to connect the S/PDIF port on the mb rear panel to your receiver directly.
2. This is purely a communication problem between the card and your display devices (TV or the receiver+TV) and this will be a problem only when you play AACS-encrypted contents. I am not sure how to fix it. Maybe using AnyDVD HD (decrypting contents in realtime) is the only solution.
Onboard HDMI audio: You need to understand that the GIGABYTE board includes two separate independent audio codecs
- Realtek ALC889A to which the rear panel S/PDIF optical and the internal S/PDIF header are connected. GIGABYTE support is wrong!
- HDMI audio controller which controls audio part of HDMI when you use the onboard HDMI and is integrated in the chip (so no wiring is necessary). Again you have to choose the correct sound playback device in Windows and you have to install the correct driver to get it to work.
post #1832 of 18891
Originally Posted by renethx View Post
Fratar
I'm confused regarding the audio with this board and the realtec alc889a.
Cyberlink tells me Power DVD 8.0 will only downsample AACS protected media.
Other people tells me it still downsamples ALL, AACS protected or not.
HDMI 1.3 with audio is (according to Cyberlink) not supported in 8.0 still, but will be supported in 8.5 coming "soon".
So, what audio can I actually get from my bluray dts hd and bolby true hd discs through analogue outs on GA-MA78GM-S2H ??
post #1833 of 18891
Mascot
Perhaps you will get 7.1 channel 16-bit/48kHz (i.e. downsampled) audio from ALC889A analog with PowerDVD 8.0 and 8.5. It looks like sound devices supported by 8.5 are not so many (only ASUS and Auzentech?).
post #1834 of 18891
Sigh... ok, I'm having trouble narrowing things down for my htpc.
Once again, I'm looking for hd and limited gaming. I'm planning on greatly overshooting what would be required for that though, just to be extra safe and somewhat future proof.
I'm planning on waiting for the hdmi sound cards to release
First of all, how long until they release? (If anyone has any suggestions for informational sites for that type of thing it would be greatly appreciated)
Second, I'm going with something along the lines of the atx premium 2 recommendation on the first page.
I'm planning on definitely sticking with the radeon 3870 (don't think I'll need to do crossfire unless someone has a suggestion otherwise)
What I'm not sure about is the mobo. Should I just go with the MSI K9A2 Platinum 790FX ATX as suggested or hold off until I purchase a sound card and get something newer? I assume that that mobo would be fine, I just want to make sure. Also, I don't think I need quad core. If I go dual core instead what would be a good cpu mobo combo to go with to match up with the 3870?
(I'm really new to all this. Luckily, my friend is doing the build for me. But he needs me to finalize my decisions on what I want so he can get started)
I really do appreciate all the help.
post #1835 of 18891
Mascot
Why would I get downsampled audio if I use Any DVD HD to remove AACS?? Cyberlink told me in their reply that It downsamples in Power DVD 8.0 on AACS protected media.
Are they lying?
/edit
No, obviously they're not lying but since there are no secure path for AACS protected audio PDVD8 simply has to downsample everything to 16/48..
Why couldnt Cyberlink simply say so?? They like politicians, you ask them one thing and the reply another question you didnt even ask...
post #1836 of 18891
Fratar
I bought the xfx model specifically because it came with a dongle though it's dvi-D instead of I and not duallink (could this be part of the problem?). I've tried connecting s/pdif on the rear panel directly to the reciever and no dice. I even pulled out the card and used just the back panel hdmi (which should carry audio, correct?) to connect to the receiver and still no audio, and in addition, the display res was limited to 600 x 400 (or something close) and wouldn't let me change it.
Also, I have anydvd which worked fine for regual dvd's, but when I put in a blu-ray movie anydvd timed out and became unresponsible. It's very frustrating. Thank you for all your help though.
post #1837 of 18891
lern2swim
HDMI sound cards from Auzentech and Asus are expected in Q2 IIRC. CyberLink said PowerDVD will support them with a patch (8.5) by the end of June.
The main reason for choosing MSI K9A2 Platinum is its brilliant number of PCIe x16 slots (enough for CrossFire and a storage controller card at the same time). If you are not interested in CrossFire or storage controller, then GA-MA790FX-DS5 is another good choice. It supports up to 4 PCIe x1 devices (HDMI sound card, TV tuner etc.).
If you play modern DX10 games, Phenom X4/X3 or Athlon 64 X2 2 x 1MB L2 cache (Windsor core) is recommended. For transcoding, Phenom X4 is the best. Otherwise Athlon X2 5000+ Black Edition (65W Brisbane core) or Athlon X2 4850e (45W Brisbane core) is a good choice.
post #1838 of 18891
Fratar
Check the following three points.
1. Install the latest driver for ALC889A (and GeForce 9800 GTX). In case you haven't, you can download it from
- Realtek audio codec driver. You can also download the ATI HDMI audio driver here (necessary for the onboard HDMI audio).
- NVIDIA GeForce driver
2. Connect the optical S/PDIF connector of the rear panel to the receiver (to eliminate the possible dongle issue out of equation).
3. Select S/PDIF (Realtek HD Digital something) in the "Sound" dialog box.
4. Open Realtek Sound Manager > Audio I/O. Configure it correctly. Test your speakers here. If you can't hear sound, recheck audio cables. If no sound, the mb (onboard audio) could be defective.
The onboard HDMI audio should work too, but this has nothing to do with Realtek ALC889A (HDMI audio controller is different).
AnyDVD HD may not work for some movies, I am not sure of this point.
post #1839 of 18891
Downsampling everything (AACS-encrypted or not) was confirmed by w1seman.
post #1840 of 18891
Do you have the Windows default audio set to HDMI? And PDVD set to 6-channel? (Don't set PDVD to HDMI, as it often doesn't work.)
post #1841 of 18891
Question
I have a new HTPC with the following:
GA-MA69GM-S2H
4 Gigs DDR2 800
Sapphire Radeon 3450 Passive
37" Vizio LCD 1366x768 connected via an HDMI/DVI cable
Monoprice 4-1 HDMI switch
Vista 32
1. I get great video in VMC at 1080i setting in Catalyst. Bluray works fine in PDVD. The desktop is blurry at any resolution I have tried through HDMI/DVI. Using VGA, I can map 1:1 and it is clear. Will Powerstrip really fix this so that I can stick with HDMI? Or can I upscale DVDs or get true HD through VGA?
2. The reason I am considering VGA is that when resuming from S3, I don't get a display. I have the HDMI switch set and the TV is on before I resume. The only solution is to restart Vista. I have read all I can find on this and tried forcing detect, etc. in CCC.
3. Is there a good reason for me to try Component? The card comes with a dongle.
post #1842 of 18891
Fratar
Thanks. The "Sound Dialog Box" hasn't givem me many options and there isn't a configure button or anything like that. Basically they offer a pass though and quality settings. Is there something specific I should be looking for and doing? If so, can you give some details. Thanks.
post #1843 of 18891
ABMAGFAB,
I'm not sure what you mean by the windows default audio or the PDVD. Can you elaborate? Thanks for your help!
post #1844 of 18891
Look at this picture. This is a different motherboard (GeForce 7150), but your dialog box should look similar. "Realtek Digital Output" is S/PDIF from the Realtek audio codec (ALC889A in your case) and you have to select it. "Speakers" is analog from the Realtek audio codec. Right-click the icon and select "test", you should hear sound.
AbMagFab is talking about the onboard HDMI. If you want to get audio through the onboard HDMI, you have to choose "HDMI Audio" in "Sound" dialog box (he said "have the Windows default audio set to HDMI"). PowerDVD setting is of course necessary when playing back a BD movie with PowerDVD.
post #1845 of 18891
Thanks, I've been on that screen and selected Realtek Digital Output, but I haven't tested it from there. I'll give it a shot. Would the "HDMI Audio" be the NVidia HDMI Audio Device shown on that image? Thanks.
post #1846 of 18891
Yes. In your motherboard, the name is different.
post #1847 of 18891
Hi renethx
just to follow up on the last post I made a couple days ago, Gigabyte emailed me back saying that the mother board did not support a case mounted lcd screen like that on my grandia. So, my question now is what would be your recommendation on a board that would fully support all the features of a SilverStone Grandia SST-GD01B-MXR case with LCD and IR display? I actually prefer intel boards if applicable. All of the other parts are from your mid range atx set up listed on the first page of the forum.
Anyone interested in a minimally used GIGABYTE GA-EP35-DS3R Intel P35 chipset ATX board?
Mike
post #1848 of 18891
How much do you want for it?
post #1849 of 18891
My "Sounds" section (with the image you referenced) is only giving me the options of "Speakers" "Headphones" and "Digital Output Device" which I have found out is the optical out on the back of the mobo which actually works now. It's not giving me an option for HDMI sound through the videocard. Why is that?
It is inconvenient to connect hdmi to the tv and optical out to the receiver (because explaining to other people how to watch a movie will be a continuous hassle), but I'd be willing to do it. However, I keep getting intermittent static on the tv audio (though the receiver seems to be fine). It will be silent for a while, but there there are numerous bursts of static. How can I fix that? I updated the audio drivers already.
Also, if I pick up a discrete sound card, will I be able to hook up the video card and sound card to send the audio though the video card? Is it worth it? Thanks.
post #1850 of 18891
http://www.staples.com/webapp/wcs/st...&cmArea=SEARCH
i have that keyboard and noticed on the top right corner of the keyboard it has a power button,if thats to turn off and turn on the keyboard how would i do that,my processor doesnt get here till wedesday in the mean time i can try to figure out how to do that heh
post #1851 of 18891
Hi All
I am looking to build my 1st HTPC and am looking an intel mATX board.
However I am unsure of which HTPC case I should use as I want something that is slim. But my concern is that the graphics module will have issue fitting into the shortlisted cases. Graphics module I am considering are the 8600 or 8800 range.
As for cases I am shorting listing Silverstone LC02, Silverstone LC11 and Antec Fusion 430. The latter is my preference.
Other points is that I am looking to use one SATA HDD and one optical drive.
Appreciate if some members to share their experiences with the above casings.
Many Thanks
post #1852 of 18891
Originally Posted by DexS View Post
Hi All
Many Thanks
I am using a Silverstone Grandia 2. It's a beautiful case and it fits my 9800gtx with no problem. But I have had a problem fitting the blu-ray drive and the psu. They both want to occupy the same quarter in. This may just be the components I've chosen (LG combo HD and Blu-ray and the Corsair 520w modular).
post #1853 of 18891
i recently have a pc. this is my pc config:
gigabyte p965-ds3 v1.1
i think i have e8300
i just bought a ati 3450 ( so this is okay.)
what kind of thing i have to upgrade so i can watch hd movies.
post #1854 of 18891
The HDMI audio from 9800 is actually Realtek ALC889A, so you won't see another HDMI audio besides ATI HDMI Audio in the Sound dialog box.
I am not sure of the cause of intermittent static. When does static occur? What is the "tv audio"? Audio from the TV speakers or TV programs'audio from the TV tuner installed in your system?
If you use S/PDIF pass-through to the graphics card from a sound card without an internal S/PDIF header, you will need a coaxial S/PDIF bracket.
post #1855 of 18891
Hi All
GeForce 8600 GT, 8600 GTS, or 8800 GT fits Antec Fusion 430.
post #1856 of 18891
Do you have any trouble in watching HD movies? Your system looks OK. BTW are your sure your processor is E8300? GA-P965-DS3 does not support FSB 1333 MHz processors.
post #1857 of 18891
There is a code error in ATX Recommended Systems's section.
post #1858 of 18891
Thanks Renethx,
But I don't see an initial HDMI audio (nevermind another one ). The icon I see seems to relate only to the digital audio from the mobo's optical port (I presume, since that works). How come it's not registering an HDMI audio at all?
The static occurs through the TV speakers. I have muted them and am passing audio through the HT Receiver via optical cable, but the static on the TV speakers almost sounds damaging. It will be quiet and then a harsh jagged sound (not an analog "snowy picture" sound).
If I'm understanding your soundcard comment correctly, I would ahve to buy a soundcard and rig the coax from outside the pc back in through an unused slot and then connect it to the videocard? There isn't a conection similar to SLI where it goes from the top of the sound card to the top of the video card (which is where the video card's audio input is already)?
I'm starting to think I should have gone with the 3870 x2 and avoided this hassle.
B/T/W - my LG Blu-ray combo player is not playing the BR discs. I think it may be the handshake issue you described, but AnyDVD is not helping, or even allowing me to rip the disc to the HD. I keep getting an error. I am trying to work through Slyfox's support to correct it though.
Thanks for all your help!
post #1859 of 18891
Fratar
Perhaps I don't understand your problems well. You connect the internal S/PDIF connector to the graphics card, then connect HDMI out from the graphics card to the TV. You have sound. But you hear occasional static noise. Right?
If you connect HDMI out from the graphics card to the receiver, then do you hear such noise from the speakers connected to the receiver?
AFAIK, many sound cards have only external S/PDIF so that you need a S/PDIF bracket if you want to connect to the graphics card.
As for video, do you have a HDCP problem with the onboard video? And does the onboard HDMI audio work well (no static when connected to TV directly)?
BTW the picture below is the Sound dialog box of a system consisting of GIGABYTE GA-P35-DS4 and GeForce 9600 GT. GA-P35-DS4 has the audio coded ALC889A (the same as yours), but has no onboard graphics. 9600 GT has an internal audio connector and it is connected to the internal S/PDIF header of the mb. There is no HDMI audio icon in the dialog box. But I can hear audio from HDMI from the graphics card just fine. No special setting is required. Just connect the cable internally and select Realtek Digital Output. That's it. The Sound dialog box shows only the actual audio controller (Realtek ALC889A). The graphics card's HDMI is to multiplex video from the GPU and audio from ALC889A's S/PDIF. None of the GeForce cards has an actual audio controller, unlike ATI-AMD.
post #1860 of 18891
Fratar
I apologize for confusing this. Currently, I connect hdmi from the video card to the TV. Audio isn't connected from the spdif header to the videocard because I can't get it to work. However this still makes the TV audio have the static sounds (but I'm not sending audio so I don't understand why that is). My response has been to turn the TV volume to 0 and connect the audio optical cable from the mobo to the HT receiver.
Also, if what you're telling me is that the icon wouldn't identify it as hdmi audio out then it should be working, right? How can I diagnose this problem?
