AVS › AVS Forum › Video Components › Home Theater Computers › Guide to Building a HTPC, Workstation and Server
Guide to Building a HTPC, Workstation and Server - Page 613
post #18361 of 19097
Just got this deal alert in an e-mail from TigerDirect.
Don't know how it is performance-wise, a good way to get into SSD maybe.
120Gb OCZ Vertex Plus SSD $99 After Rebate.
post #18362 of 19097
Originally Posted by renethx View Post
- 23Hz for film
- 59Hz for video
Can I please ask how well the Llano APUs you tested handled the 23hz setting with 23.976 fps film? I see a lot of debate on which chips can handle 23.976 fps files and am hoping that it's straightforward with Llano and the Catalyst drivers. Is it as simple as switching to the "23Hz" mode in Catalyst to get 23.976 output? Thankyou!
post #18363 of 19097
Performance and reliability are the specs to look at in SSDs imo. I don't know the answer for either of these on the Vertex but potential buyers check the forums for the specific drives they like: http://www.ocztechnologyforum.com/fo...ort&order=desc
"Vertex" sounds like it must be an older generation of SSDs. OCZ is up to Vertex 3 now among others.
(burned by my Vertex 2 after 5 months)
post #18364 of 19097
The clock depends on each individual chip. The worst and best I have seen in Llano chips are:
- 23.97555Hz, a frame drop every 37m
- 23.97585Hz, a frame drop every 1h51m
They are much better than Intel and NVIDIA (only NVIDIA custom resolution can be better). madVR can change refresh rate based on the contents automatically.
post #18365 of 19097
  Codename Radeon cores/CUs Clock Memory TUs ROPs Power Price
HD 7770 Cape Verde XT 640/10 1000MHz GDDR5-4500 1GB 128 bit 40 16 80W $129?
HD 7750 Cape Verde Pro 512/8 800MHz GDDR5-4500 1GB 128 bit 36 16 55W $110?
Source. If you are not satisfied with Llano, just go with HD 7750 or 7700.
Update
There are now lots of reviews on 7770/7750 on the Internet. Notably, AnandTech.
post #18366 of 19097
post #18367 of 19097
Originally Posted by jrolmstd View Post
tried the netsh disabled, uninstalled drivers, installed new drivers from realeck, and flipped it to a work network. No change
Last post on this. I set up shared directory on the server that was not in the RAID array. Transfer speeds for the same file tested with in the past hovered around 80 MB/sec where as when the target was a directory inside the RAID array it would bottom out at 15 MB/sec. Would seem to eliminate any networking issue being the cause of this. Looks to be more of an issue with the software RAID being used than anything else...
post #18368 of 19097
FWIW-
I'm using a 3ware 9500s-4lp I purchased on eBay(seller=belmonttr) for $10+s/h. Works great!
post #18369 of 19097
Wow, had no idea it varied within the Llano series! Thanks.
Another Llano setup question - is there a "sweet-spot" of how much system memory to assign to the on-chip graphics? I have an 8GB DDR3-1600 setup, so maybe 1GB?
post #18370 of 19097
You guys are way over my head
What would a noob like me choose for a HTPC in order stream his MKV files (3D as well)?
Instead of putting together one, I think I'll be better off buying something off the shelf. Any recommendations? I have a BD Player already.
post #18371 of 19097
The max you can assign in Llano is 500MB and it's the one you should set "Frame Buffer" to in UEFI BIOS.
post #18372 of 19097
please post a new version of your guide!
post #18373 of 19097
Rene,
I am facing an issue with my 5670 card - I want to use both the DP and HDMI outputs (one for the Tv, one for the Receiver/projector) but no matter what I do, I can only get the sound from one of the digital outputs (the one activated first). The only way to switch between them is to reboot with either the receiver or the TV turned off, so the sound is assigned to the active port.
After browse different posts it seems to me that NVidia card offer the ability to output sound to 2 different digital outputs. Is that correct? Which model would you recommend for HTPC exclusive use (Live TV, DVD, Blu-Ray)? Any model with DP and HDMI outputs or would I need a DVI-HDMI adapter?
post #18374 of 19097
Sure, soon.
post #18375 of 19097
Yes, NVIDIA supports dual audio stream (over HDMI and DVI [with a generic DVI-HDMI adapter]). GeForce GT 430, ASUS fanless or PNY 1-slot low-profile. The card also supports dual 1080p video stream. But dual 1080i is difficult (there are not enough shaders for dual deinterlacing).
post #18376 of 19097
Thanks Rene. Looks like I have some shopping to do today.
Any reason to choose the PNY over the Asus w/fan model below?
http://www.newegg.com/Product/Produc...b=true&Page=10
post #18377 of 19097
PNY in case you need a 1-slot (and low-profile) card. If there is enough room for a 2-slot card, ASUS is another option (don't buy this ASUS model, DDR3-1200 is too slow). If the case supports full-height cards, go with ASUS fanless.
post #18378 of 19097
In terms of fan noise, are both Asus and PNY similar? That's my main concern.
Ideally I should get the fanless one, but it won't fit my case.
post #18379 of 19097
PNY is quieter at idle and video playback.
post #18380 of 19097
We are here because we build them, so you probably won't get much help on recommendations on pre-built HTPCs although nowadays many of the PCs on the shelf will work fine streaming mkv files with the addition of some freeware. With the guides here it really isn't too difficult to build a simple, cheap, nice looking HTPC.
post #18381 of 19097
Llano APU dethroned the golden combination of Core i3-2105+Z68+DDR3-2133. (DDR3-2133 is only available as 2 x 4GB or higher kit, that is pretty expensive compared with DDR3-1600 2 x 2GB, no need of overclocking, DXVA2 compatible AMD GPUs was implemented in LAV Video Decoder etc.) This will be reflected in the next issue (available very soon). I apologize for the long delay (as usual lately).
Can I add a HD 6570 to my Intel G850 setup and get the same perf with DXVA2 as the A6-3500 does by itself?
post #18382 of 19097
Yes.
post #18383 of 19097
Hi,
My head is gone reading through all this. Just woundered if someone could advise me on a system that will play 3D ISO, 3D Blu Rays flawlessly through my 3D TV with full HD audio. Thats all it will be used for, Not fussed about gaming.
My main problem would be, the case needs to be no more than around 250cm in depth and it would have to have a remote to make it family friendly. It doesnt really matter on the height and width.
I dont need a Blu Ray drive as I will run it all from the HDD, Also I dont need a HDD as I have a 2tb.
My budget is £250-£350.
Thanks very much.
post #18384 of 19097
When I read about how many physical drives a RAID or HBA card will support, I see numbers reaching up to 256 for a 8 port card but when I check out the break out cables for these cards (sas --> sata) I see a cable with 1 connector on one end and 4 connectors on the other end. The 8 port cards only have 2 physical connectors. This would seem to support a maximum of 8 physical drives.
What am I missing here? I am setting up a system with 15 drives. What would the configuration of Raid and HBA cards & cables look like?
thanks
post #18385 of 19097
Originally Posted by jasjw View Post
Hi,
Thanks very much.
I3-2105. Z68 Motherboard, 4 gigs of 2133 Ram. A basic case and a power supply. Rene's guides will give you further details.
post #18386 of 19097
Hi,
Thanks very much.
There are several mini-ITX cases with depth < 250mm. Check my guide. If you have a HDMI 1.4a AVR, AMD Llano is another choice.
post #18387 of 19097
thanks
256 can achieved by using multiple SAS expanders such as HP 468406-B21 SAS Expander, $289.
post #18388 of 19097
So a SAS expander is used in conjunction with the RAID card? Is it physically connected to the raid card through a cable or is it internal through the PCI slot? Looking to run this under win 7 so maybe not this specific card but something similar?
post #18389 of 19097
RAID card + SAS expanders connected with SAS cables. *Official* HP SAS Expander Thread
post #18390 of 19097
Got it. Thanks for clarification and link.
