I guess you'd better ask in the server forum (sticky), where server professionals gather...
AVS › AVS Forum › Video Components › Home Theater Computers › Guide to Building a HTPC, Workstation and Server
Featured Stories
Topics Discussed
- topicComputers
Related Forum Threads
- Recommend 7.1 Surround Receiver (range $250-$450) Last post on 3/5/10 at 8:48am in Receivers, Amps, and Processors
- Official Logitech Harmony 900 thread Last post on Yesterday at 12:00 pm in Remote Control Area
- *Official* Denon AVR 1909/789 Thread Last post on 5/14/13 at 4:02pm in Receivers, Amps, and Processors
- Help, Onkyo TX-SR607 is randomly shutting off. Last post on 5/3/13 at 8:59am in Receivers, Amps, and Processors
- tx sr607 front panel display problem Last post on 5/17/13 at 12:49am in Receivers, Amps, and Processors
Guide to Building a HTPC, Workstation and Server - Page 615
Gear mentioned in this thread:
post #18422 of 18891
3/2/12 at 7:05am
My intention is to build a future proof; Ivybridge ready Sandybridge system.
Upcoming Ivybridge CPUs will be supported on existent H61, H67 and Z68 platforms with a BIOS update. My choice will be in favor of Intel Z68 (B3).
And motherboard should have PCI E third-generation expansion ports since future GPUs will take full advantage of PCI-E 3.0. (G3)
http://micro.msi.com/mc2/features_peg3.php
-FYI, MSI only supports G3 on their H61 and Z68 cards:
http://event.msi.com/mb/22nm/
Furthermore, only Z68 from the Sandy family supports SRT. (http://en.wikipedia.org/wiki/Smart_Response_Technology)
Finally, I have almost decided to this configuration:
Mobo: MSI Z68A-GD55 (G3)
CPU: Intel Core i3 2130 (I may change it with an Ivybridge CPU later.)
CPU Cooler: Thermaltake Frio advanced CPU cooler.
Memory: GSkill 8GB (2*4GB) RipjawsX DDR3 1600 MHz Ram
GPU: iGpu (I may use my existent nVidia card later.)
SSD: OCZ 60GB Vertex3 series SATA 3.0 SSD (for system)
HDD: Seagate Barracuda 1TB SATA 3.0 64MB Cache HDD (for storage)
OS: Win7 64
Thanks in advance for your comments.
EDIT: I might give it a go with SRT with a 500 GB Barracuda and OCZ. This case I will use that 1TB Barracuda for storage separately. But I'm not sure it is gonna give better performance than my above configuration.
EDIT: Additional information on LGA 1155:
http://en.wikipedia.org/wiki/LGA_1155
EDIT: Ivybridge ready mobos from Gigabyte and Asus:
http://www.gigabyte.com/press-center....aspx?nid=1048
http://event.asus.com/2011/mb/PCIe3_Ready/
EDIT: Asus seems to me support G3 only on some Z68 models?
OS: Win7 64
post #18423 of 18891
3/3/12 at 4:28pm
- mifronte
- Trader Feedback: 0
- Want to be a DIYer
- offline
- 228 Posts. Joined 12/2005
- Select All Posts By This User
For the MicroATX Mid-Range Build:
01. If noise is not a concern, will the Core i3-2105 cooler be sufficient?
02. Is an Antec EA-380D Green 380W 80 PLUS Bronze be sufficient or do I need the 430W PSU?
03. Can I use G.Skill F3-12800CL9D-4GBXL memory? It is listed on the MB's compatible list.
This won't necessarily be a HTPC, just a general PC which may have to perform some HTPC tasks on occasions.
I think there is a great confusion about the support for PCI Express 3.0.
Every H61, H67, P67, or Z68 chipset motherboard with only *one* PCIe x16 (physically and *electrically*) slot always supports PCIe x16 3.0 as long as you use Ivy Bridge. This is because the x16 slot is directly connected to the processor (you can see it easily by looking at the mb PCB), the mb is totally irrelevant here.
If there are two or more PCIe x16 slots, electrically x8 or x16, however, then the mb must use PCIe switches supporting PCIe 3.0 to be ready for PCIe 3.0 graphics. These mb are advertised as "PCI Express 3.0 ready".
Be careful, even lots of hardware review sites don't tell this trivial fact.
1. Yes.
2. Even 150W PSU is enough (check the max power consumption in the feature table).
3. No problem.
post #18426 of 18891
3/4/12 at 6:54pm
I finally bought and assemble my htpc.
All movies mkv plays great. The picture quality is much better than ion and even hdmi sounds seems better. The i3 2105 is really fast, powerfull and with crucial m4 everything runs really well and smoth.
The only not good point of my htpc is the optical drive (samsung sh b083l) that I bought in sale at 29 euros, but i already regret. In 10 cd audio i tried, 3 make a weird noise, like metalic noise at the background and 1 it simply cant play. The drive don't detect it, is the same as don't have any cd.
In bluray playback I tried 2. One (george michael) played 100% well, the other the optical drive makes more loud sound while is playing and it stutter the image.
I updated the firmware. I also tried format the drive in AHCI and in IDE. All without success.
And i am not able to put external player in XBMC, drive start make a weird noise.
I will put some pictures tomorrow.
post #18427 of 18891
3/4/12 at 8:34pm
post #18428 of 18891
3/5/12 at 12:22pm
post #18429 of 18891
3/5/12 at 3:14pm
- gsr
- Oppo Beta Group
- online
- 6,540 Posts. Joined 4/2001
Make sure you check the firmware version on your M4 drive and upgrade if you don't have the latest:
Crucial M4 SSD Frimware Update Available Now for 5000 hour problem.
post #18430 of 18891
3/5/12 at 4:12pm
I have an older Yamaha RXV-2700 HDMI 1.2a capable AVR and only supports surround LPCM. No DTS-HD support or similar...
Do you guys know if these newer mobos are able to pass both sound and video through the HDMI input of my receiver? Or am I limited to the Optical S/PDIF option for the sound output coming from these boards?
- GIGABYTE GA-Z68MA-D2H-B3 (INTEL)
- GIGABYTE GA-A75M-D2H (AMD)
post #18431 of 18891
3/5/12 at 4:30pm
What "refresh rate" do you use in intel drive? I use more .mkv files and I put it in 60Hz but to be honest I don't understand nothing about it.
Another thing I notice in XBMC if I have dxva2 enable it dont work well in some movies so I turned it off. Do you have more tips like that?
Thks, done
Thks, done
You can decode all HD audio (TrueHD/DTS-HD/DD+) to multichannel LPCM in PC (instead of in a HDMI 1.3 AVR) (how) and send it to your HDMI 1.2a AVR. Any HDMI solution supporting multichannel LPCM will work:
The ideal refresh rate depends on the content:
- BD movie encoded at 23.976Hz: 23Hz (90% of BDs)
- BD movie encoded at 24Hz: 24Hz (5% of BDs, mainly available in Europe)
- BD video (1080i60): 59Hz (3% of BDs)
- BD video (1080i50): 50Hz (2% of BDs, mainly available in Europe)
- DVD movies (NTSC): 23Hz
- DVD movies (PAL): 25Hz
- DVD video (NTSC): 59Hz
- DVD video (PAL): 50Hz
DXVA2 in XBMC does not work well with Intel graphics.
post #18434 of 18891
3/5/12 at 7:01pm
post #18435 of 18891
3/6/12 at 1:07pm
post #18437 of 18891
3/6/12 at 4:15pm
Greetings! Thanks to the OP for putting together this guide. I donated $20. Seems like a lot of sweat has been put into it.
How are the donations these days? The original post shows that you have been getting $100-$200 per month back in 2010. Are you getting better/more donations now such that you're able to fund your research? Thanks again.
post #18439 of 18891
3/6/12 at 4:52pm
Dude, it seems to me your destiny as far as Intel and AMD exist.
Those, so-called, huge companies must donate to you and the others. Everybody works for them for the sake of a kiss. ( I know, that doesn't match with native English, but hopefully you understand what I mean.)
post #18440 of 18891
3/6/12 at 5:11pm
I mention a few times a month on AVS that people should donate to you for your work.
I know with my free guide here at AVS I have received a grand total of 31 donations in the 13 months I have had and updated my guide (which admittedly is no where near as detailed as yours) for an average of about 2 donations per month.
Needless to say when I started the work on my blog I made it a pay for service. That's the main reason why. There is simply no way I can justify the cost and exorbitant amount of time required in keeping it up without some sort of compensation. And I have kept mine advertisement free as well.
So what am I saying? Donate to renethx or he will be gone (out of necessity).
post #18441 of 18891
3/6/12 at 6:20pm
assassin, thanks a lot to you for being so open to us.
And thanks all the respectful guys like rene and you.
Thanks for your works.
However, do not forget we/you are masturbating while the others are making money.
WHERE ARE THEY?
WHY DO THEY NOT SUPPORT YOU WITH (at least) THEIR F*** PREMATURE (as always) HW/SW?
WHERE ARE THEY?
post #18442 of 18891
3/6/12 at 8:55pm
The guide is a great starting point for a system build. So much of the research work is already done that it makes designing your new system way easier (and less costly) than doing all the grunt work from scratch.
Even with that, the real value is Renethx's continued support from within this thread for anyone that asks, even the sponges that do not show their appreciation with donations.
Renethx, I never did care for the consecutive clause much but if you were to setup a lifetime membership to your guide for $50, I would buy the first one to kick it off
ps. It would be nice if the lifetime membership was transferable to a new membership if this guide where ever to go private
post #18443 of 18891
3/7/12 at 4:54am
@renethx;
Very happy with my 'bedroom' small form factor fully passive HTPC based on the asus E45M1-I DELUXE with a M350 Universal Mini-ITX Case. Fits behind the TV perfectly. Thanks for your help on this.
Unfortunately a new investment is coming up and I need to replace my core system that:
a) Acts as the media server for the bedroom system, sonos etc.
b) is on 24/7 (as it also is used to manage all downloading etc.)
c) Is the DVBlink server (IPTV) for bedroom system and other devices (like Ipad etc.)
d) directly connected to my Receiver/TV (HDMI) running WMC (win 7) and used for live TV and all other Media (so core entertainment system)
So in short it's kind of a combo of a mediaserver and normal HTPC. No need to be perfectly quit or beautiful, just to be efficient, powerful (sometimes the un-rarring/parring of files and watching a 3d H264 movie hits the max perf of current system) and reliable (!).
My Q: How can I best mix and pick from your guide to get the best system? I would like to re-use my recently purchased GT-430 but happy to get rid of the rest (based on an intel Core2 6400 @ 2.13)
Originally Posted by Tyfoon2
@renethx;
@renethx;
The answer depends on your usage.
- The max number of HDDs you want. A normal HTPC case can hold 2-8 HDDs. Server cases in my guide: 15-24 HDDs.
- Transcoding: If you do transcoding via DLNA, you may want a quad-core processor.
You may want to wait for the upcoming Intel Ivy Bridge processor (April 29), in particular Core i5 3570K with Intel HD Graphics 4000, $225. A discrete graphics card always consumes 10-15W more. So you may want to stick to integrated graphics (depending on how electricity costs in your area).
post #18445 of 18891
3/8/12 at 12:58pm
max 8 disks is enough
Any specifics for the PSU for a system that is on 24/7? Found out that these often are not fine with running 24/7 for years.
Thanks for the Intel tip. Will wait, no immidiate need if it keeps running.
Is the new HD4000 comparable with a discrete card (incl. bitstreaming capabilities etc.)?
PSU wastes power to convert AC from the wall to DC, the ratio is called "efficiency". A PSU of higher efficiency (80 PLUS, 80 PLUS Bronze, 80 PLUS Silver, 80 PLUS Gold, 80 PLUS Platinum in the order of increasing efficiency). For example, if the system draws 80W DC (typical usage of your system at video playback),
- A PSU of 75% efficiency has to draw 80W/0.75 = 107W AC
- A PSU of 85% efficiency has to draw 80W/0.85 = 94W AC
The difference is 13W.
Yes Intel graphics is good for video playback including 3D and HD audio bitstreaming.
post #18447 of 18891
3/8/12 at 3:10pm
- kesawi
- offline
- 253 Posts. Joined 6/2006
I've assembled my new HTPC and am now in the process of configuring the bios and windows. I have a few questions regarding some settings.
- I have a Gigabyte GA-Z68MX-UD2H-B3 Rev 1.3 motherboard with revision F13 bios. One setting that I can't seem to find an answer on is what to set the On-Chip Frame Buffer Size to. The default is 64MB+2MB for GTT and it can be set anywhere from 32MB+2MB for GTT to 480MB+2MB for GTT. The manual describes the funcation as "Frame buffer size is the total amount of system memory allocated solely for the onboard graphics controller. MS-DOS, for example, will use only this memory for display." I have 4GB of RAM and whatever value I set it to is deducted from the total RAM available under Windows 7. I'm not running a discrete graphics card. Do I need to set it at anymore than the default.
- When installing Windows 7 it creates a user account which is assigned administration rights by default. I would prefer if the access rights for this main user account were changed to a normal user so as to prevent my kids from making changes to the system. Does the active user when running WMC (or associated programs such as PowerDVD, TMT, etc) need to be an administrator?
- I've been following Assassin's excellent paid guides (I highly recommend you subscribe to them if you're setting up a HTPC for the first time) and am now up to Guide 2. I wish to complete as much of the software setup on a PC monitor as I can before hooking the htpc to the our HDTV as my partner will not appreciate me monopolising the TV to do so. Can I continue through all the steps in the guide and come back to setting up the HDTV later without having to make too many changes all over the place? I assume setps 1 & 3 in Guide 2 can be done at anytime?
1. Default. This is a bit mysterious, but the driver will intelligently detect physical memory available and allocate necessary video memory.
2. Most operations (e.g. playing back videos, watching TV) can be done without the administrative privilege. The administrative privilege is required to change the system configuration, install a program, update Flash Player, for example. If you log in as a normal user, you will be asked to enter the password of an administrator in this case.
3. I haven't subscribed his guide yet.
You'd better set up your system as much as possible using your PC monitor (as using kbd/mouse is usually easier in a work desk than in a couch). Do final touch up by connecting the system to AVR/TV. Even then you can control your system (e.g. install a program) remotely from a desktop system if OS of the HTPC is Windows 7 Professional or Ultimate.
post #18449 of 18891
3/8/12 at 4:55pm
What do you think about picture/audio quality beetween intel hd3000 and ati hd6870?
I said hd3000 was perfect comparing to ion. But now I tried hd6870 that I bought to another pc and omg, the picture quality seems even more perfect. Big range of colours and more smooth. What do you think about it? Is psicological lol?
Many people *think* that AMD is better than Intel and NVIDIA because of post-processing (this poll).
Eventually PQ is subjective.
- Guide to Building a HTPC, Workstation and Server
Currently, there are 1657 Active Users
(383 Members and 1274 Guests)
Recent Discussions
- › Which subs to consider for my setup? Bach grands, onkyo txnr818 5 seconds ago
- › VT60 Settings 21 seconds ago
- › *Official* Pioneer SC-1522 9.2 Network ready AV receiver owners thread 27 seconds ago
- › New Guy overwhelmed... Any help greatly appreciated! 31 seconds ago
- › Black Diamond from Screen Innovations? 43 seconds ago
- › Official SVS Owners/Support Thread. 53 seconds ago
- › "High Definition Benchmark" BD Edition by Stacey Spears and Don Munsil 1 minute ago
- › 2013 Panasonic Settings/Issues Thread 1 minute ago
- › Official Wii U discussion thread. 2 minutes ago
- › newbie needs help with selecting a surround sound 2 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
