Originally Posted by Xuivo
Thanks renethx. Some more question though, as for the expension cards, is there a possibility I need more than four in the future? I plan to have a decent video card for occasionnal gaming, something to record TV, what else can I put in it?
Also, have you heard about controlling the HTPC with a Playstation 3 or X-box 360 remotes? In one case, i would need bluetooth, while on the other, RF... Is it feasable? Since I plan to run emulator, it would be great.
Finally, do you suggest to put vista 32 or xp 32 in a HTPC these day? And using the 32 bits limits me to 3.2 GB of ram right?
Oh, and finally... Concerning the sound, I'm I ok with the 7.1 from the video card (HD4850?). Like I've said, my receiver does not internally decode the new format. My PS3 pass those as PCM, so I guess the PS3 is decoding them. Will this card do the same thing? And if I want to use my HTPC as a HDPVR, do I need a sound card then?
If you continue to use just one TV tuner and don't use extra SATA controller cards, then four is enough. (Two of them are PCI which will be outdated soon; by then the mb itself will be outdated too.)
Vista. 32-bit is limited to 4GB max memory (around 3.2GB for application use).
A software player decodes HD audio (Dolby TrueHD etc.) to 5.1 or 7.1 LPCM and HD 4850 sends it over HDMI. You don't need a sound card.
