Hi guys,
I have built the following HTPC (gaming/movies):
Asus P5Q-E
Intel Q9550 (stock cooler)
4Gb Corsair Dominator DDR2 1066
Asus HD4850 1gb DDr3 w/Glaciator heatsink
1Tb Samsung (50gb OS partition)
LC Power 650W Ozeanos 140mm V2.2 (modular)
Thermaltake DH101 (no lcd version)
This is hooked up by HDMI to my Panny TH42PZ70 plasma.
The built went smoothly, apart from figuring out how to boot with both Ram sticks. Bios update, changed slot for one stick, and everything boots fine.
Then... enter the nightmare time.
Installed Vista64, Mobo drivers - all good n' smooth
I noticed some image corruption (vertical red dots columns along the screen), which I thought would go away with the Gfx drivers....
Installed the latest 8.8 Ati drivers and all hell broke loose. I was still able to pull the resolution up to the Panny's native 1900x1200 @60hz. The screen corruption then got quite worse, with vertical lines all over the place.
Tried to reboot and... BSODed. Went to safe mode, remove the drivers, reboot and... no go. The best I get is a totally distorted desktop, which goes blank after a few minutes. That or BSOD on boot.
I did manage to check the temps: 53C on idle... i don't think thats the problem.
So I really need help, please
Asus P5Q-E
RAM): 1:1.20
