Hi Folks,
I've been running my HTPC for a few months now, with picture noise on many of the channels. This is typically macroblocking, and other digital-type glitches. After much experimenting, I've found that using a separate video card, instead of the built-in motherboard graphics resolves the problem.
This is my current setup:
Cable QAM and ATSC 8VSB input. Exact same noise on both sources.
Mythbuntu 8.04. Exact same noise on WinXP MCE 2005.
Mobo: ABIT AN-M2HD AM2 NVIDIA GeForce 7050PV
CPU: AMD Athlon X2 BE-2400 Brisbane 2.3GHz ADH2400DOBOX
RAM: A-DATA 2GB (2 x 1GB) DDR2 800 ADQVE1A16K
Tuner: KWORLD PlusTV HD PCI-115 (Exact same noise with ATI HDTV Wonder)
PSU: Rosewill Stallion Series RD400-2-SB 400W ATX V2.2
HDD: SAMSUNG SpinPoint T Series HD501LJ 500GB 7200 RPM SATA
The noise is much worse on two particular channels, when they're showing SD content at 720P. But most channels are noisy. As noted above, the source of the stream does not make any difference.
So the question is, why do I get this noise with the on-board video, but not with a separate card.
Apparently the 7050PV uses system RAM, and doesn't have its own. Is it the CPU? It's certainly not being taxed, but maybe the power-saving features are interfering.
Has anybody else seen anything like this?
Cheers
Bob
Cheers
Bob
