Originally Posted by sneals2000
Sorry - you aren't understanding my point.
The video output from your airtel receiver will be PAL - that is the format used in India.
The Asus card you found is designed to accept NTSC video - that is the format used in the US. This means that the Asus card you have found will not be compatible with PAL video output from your Airtel box. Asus make different cards for PAL - but I don't know if NewEgg stock them.
You need a capture card that will accept PAL video for use in India - whether you use Coax, composite or S-video inputs.
PAL and NTSC (and there is a third format - SECAM) are all separate standards - and any receiver or TV card needs to be in the same standard to work together.
You need a PAL TV card to accept the output from a set-top box in a PAL territory, just as you need an NTSC TV card to accept the output from a set-top box in an NTSC territory.
India is PAL. The US is NTSC. They don't work with each other.
i really appreciate your point.i am cancelling the purchase.thank you very much for your effort.i will purchase a card here in local shop.
Phenom II is much better in both power consumption and performance but released only in January 2009.
