Originally Posted by scmeis1
I am dead set on 2 parts of my new HTPC. The powercolor 3850 extreme with an HDMI output. It does output sound in HD, I have confirmed that with powercolor. The other is the LG GGC-H20L for blu-ray and HD-DVD playback.
Where I am stuck is horse power. The powercolor works best with PCI-E 2.0, so the question is which direction do I go?
AMD or Intel
Intel I was considering a Q6600 w/ P35 board or X38 board.
Amd I was considering a X2 5000+ black edition CPU, but since I am ususally all about intel, do not know much about amd boards.
I think 4G of ram is plenty of throughput of HD content, sound and video.
Since this HTPC is going to be streaming from my upstairs gamer, through my home gigabit network (good to be a CCIE here). I do not need much of a HDD.
AMD or Intel
Welcome to AVS. Yes, this is the place for all HTPC related needs, bar none. Incidentally, I'm a CCNP myself by day.
Multiple cores (well, past two anyway) won't help you with HTPC duties. In this case, I'd recommend the E6750 or E6850. If you can wait another few weeks, the new E8400 or E8500 would be an even better choice. All of that horsepower can play almost anything you throw at it, especially considering that when the drivers are configured correctly (or working at all!), that ATI video card will do the heavy lifting. Even if you can afford it, I don't recommend a quad-core for an HTPC because it'll get hotter, require more (ie. possibly 'louder') cooling and use more electricity for something that we like to think of an appliance. Might as well keep keep it quiet, cool and low'ish powered for something that may stay on 24/7.
renethx has posted an Excel spreadsheet within this thread that illustrates all the motherboard options. I'm partial to the Gigabyte P35 boards myself. I don't think you'll need PCIe 2.0, but it won't hurt if you are set on an X38 board.
Assuming you run Vista, yah, 4GB RAM is great. But your HTPC won't need it unless it's doing non-video-watching duties too. I wouldn't argue against 4GB though at all.
-Robert
