Originally Posted by renethx
Have you turned on Smart Fan in BIOS? Check your BIOS Manual page 10, Smart Fan Configuration.
You can control the fan speed by SpeedFan too. Read the SpeedFan section of my guide.
Ok I enabled it, but the settings are a bit criptic.
Control Mode [Manual]
Fan Ctrl OFF(C) [010]
Fan Ctrl On(C) [020]
Fan Ctrl Start(C) [030]
Fan Ctrl Sensitive [050]
What should I change these settings to?
*update*
I went with these settings
Fan Ctrl OFF(C) [020]
Fan Ctrl On(C) [030]
Fan Ctrl Start(C) [010]
Fan Ctrl Sensitive [030]
After startup and launching media center and playing a VOB, the CPU fan hit ~1800rpm and CPU temp was 37C
now after running for a bit the fan dropped to ~1650 and CPU temp is 35C.
I can't really judge the noise level because someone is cutting grass outside. I live in an apt, so I can't really do much about ambient noise. Moving soon though
Read also my guide to see how smart fan works.
