AVS › AVS Forum › Audio › Receivers, Amps, and Processors › I'm having some issues with my LG LH-E9674....please help....
post #1 of 4
It has lag. Not much at first, but it grows worse and worse as time goes by. I bought this thing from a family member who only used it maybe 4-5 times. He needed the money and I needed a better setup. Thing is, LG only offers a 90 day warranty and this thing is like 4-5 months old.
What do I do? I'm currently researching new receivers that'd make for good replacements, but I'm kinda tight for cash right now. And I'm definantly keeping the speakers because they sound great.
Is there any way to FIX the lag? Anything at all I can do to it to make it work properly? It's just so frustrating cause the reviews say it works wonderfully and sounds very good, save for the occasional defective one lags between picture and sound.....
>_>
Also, if there's no conceivable way to solve this issue, what are some good, AFFORDABLE receivers? Preferably with a dvd player on it and that I can buy WITHOUT speakers. Like I said, I'm keeping my speakers I just need a new receiver.
Oh, and it has to have at least one component out and at least one A/V out.....(RGB and RWY)....
thanks!
post #2 of 4
bump
post #3 of 4
Uplug everything from the receiver and unplug it from the wall. Let it sit unplugged for about 30 minutes. Then replug it into the wall, find its reset button and set everything back to it's factory defaults.
Plug everything back in, reprogram it for your set up and hope for the best. If you have it connected using optical cables, try coax, or if using coax, try optical.
post #4 of 4
Is there no lip sync delay on these units?
