AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › The Official Rock Band Discussion Thread
The Official Rock Band Discussion Thread - Page 106
post #3151 of 12388
Originally Posted by NoThru22 View Post
Yes, you're reading it right. I said it a few posts ago.
It's getting so hard to keep track of all these Rock Band threads...
post #3152 of 12388
omg! do want!
http://www.youtube.com/watch?v=bToFrYPukXk
my main worry was the ion would be too big for livingroom or kids bedrooms and if your going full size might as well go roland. but that thing is barely bigger than the normal rb set. love it!
post #3153 of 12388
Man, I've got a lot of songs to replay. Obviously I was pretty far off on my recollection of songs using the green pad as a tom.
post #3154 of 12388
Hands on with the ION kit:
http://arstechnica.com/journals/thum...drums-worth-it
Frank on the Ion drums
The drums have been my big passion in Rock Band: I always wanted to be a drummer but never had the money, time, or talent to pursue the dream. In fact, I was one of those sad folks who anticipated the game by playing along to the prerelease gameplay videos with pencils on my desk. And while I may never try to transfer to a real set, I will without a doubt shell out $300 for the Ion Drums. After only a single song, I can't see myself going back to an old set without pining for the Ion.
First of all, this set is huge and durable. This isn't just a piece of plastic. It was stressed that by adding an Alesis brain to the set, you have a high-quality electronic drum kit. The unit I was playing on was covered in wires and ties keeping the complexities tightly wrapped against the sturdy frame. The cymbals were adjusted a little low for my taste at first, but everything can be moved around: the pads can be spread out, the cymbals lifted and lowered, the pedal moved up and back at will.
While the pads felt good, the cymbals were amazing. Crashing down on the crash cymbal to end a special was amazing, even if it took a while to get used to the idea of playing both vertically and horizontally across the set. I also had some trouble with the new pedal: hits only register if your foot is right at the end of the pad: oftentimes I missed a few notes because the tip of my toe (I play heel-up) was too far from the top.
Without question, the Ion drums are a luxury that only a few will truly buy in to. But there's simply no denying the fact that the new set looked, sounded, and felt great. If you want to get the most out of drumming in Rock Band 2, you need this.
post #3155 of 12388
Thanks for making me drool, Jokell.
I'm really just sick of the old drums already. My drums have been broken for over a month and my RMA is nowhere in sight. I borrowed my friends drums, which have been hardly used, and gold starred seven songs on Monday, but then last night they're dropping notes on red already. So now I may need to give my friend my new drums and RMA his. I don't even hit that hard.
post #3156 of 12388
The red and green pads exhibit a lot of problems on these sets. It seems like a fair amount of that is the vibration due to them just hanging out to the sides. Over at Scorehero somebody's come up with a mod that's a couple of support struts that sit between the legs for the base and the outer edges of the outside pads. Apparently that helps quite a bit.
post #3157 of 12388
My stock kit is now not staying up at the height I set it at (the locking pieces come loose and it drops down). Getting highly annoying, because it only happens during a song.
Those ION kits can't ship fast enough for me.
post #3158 of 12388
post #3159 of 12388
You may want to call EA. I've RMA'ed my drums twice (about to the third time) and I've received the drums within a week both times.
post #3160 of 12388
Originally Posted by thejokell View Post
Mad Katz cymbals revealed:
http://www.engadget.com/2008/07/17/m...ium-mic-and-m/
The only thing I'm even considering out of that batch is the MIC. If it has equal or better sound quality than the stock mic, I may have to get one.
I wonder if it will fit into the clip on my mic stand, though. At least they thought to put a locking button on there...
post #3161 of 12388
So we know that GHWT has more unique inputs then rock band, so my question is... will the Ion kit with extra cymbals take advantage of this and map them as unique inputs or just copy em? And is anyone sure if you can just USB from the Ion kit to the PC to make them work as electric drums? If this is the case.. my god is this a buy.
post #3162 of 12388
First point - we won't know for sure unless someone from either camp (Activision or ION) says one way or the other or until they're both released.
Second point - since it's a standard 360 controller you should be able to hook it straight up. No reason to think otherwise at this point.
post #3163 of 12388
How's this for ya? http://blog.wired.com/games/2008/07/xbox-rock-band.html
LOS ANGELES -- Own Rock Band instruments on Xbox 360? They'll work with Guitar Hero World Tour.
At Activision's E3 press conference Tuesday, Guitar Hero director Brian Bright told the crowd that if they already owned guitar controllers and drum controllers from "previous games" on the Xbox 360, they'd work with Guitar Hero World Tour.
What Activision didn't say is how that will actually work, considering that Rock Band drums have four pad inputs and Guitar Hero World Tour has five.
UPDATE: Here's how it'll work. Speaking with Bright after the conference, I found out that the game's five-button drum track, shown above center, will be compressed down to four inputs if a Rock Band drum controller is inserted.
There's also a MIDI jack on the back of the drum kit, Bright said, which will allow gamers to play Guitar Hero with any electronic drum kit by simply plugging it into the controller. You can also hook up a second drum pedal if you want to play two bass drums
Granted, I'm making an assumption here but knowing about them condensing it down to 4 drum lanes makes me think this is a total go.
post #3164 of 12388
Anyone see the clip of the guys playing 'Hot For Teacher' on Guitar Hero? The drum part was insane. The opening guitar rift was pretty crazy too. Those guys were pretty damn good. Nice to see a demo with the folks playing on expert and knowing what they are doing.
post #3165 of 12388
I actually sort of like the portable drum set idea in that link also. One of the major things that always held me back from getting it is that I don't know where I'd store all the stuff when not playing. (Pretty much all spare storage space in my apartment is used up.) Still, I don't know if I'll get that or not, but its an intriguing idea.
I wonder if adding one of the Mad Katz cymbals to the RB2 drum kit also lets you keep all 5 notes in GH:WT. I really hope so, otherwise, no matter how much better the RB2 kit is, I'll probably get the GH:WT one, just so that I can get the full experience in both games.
post #3166 of 12388
actually that portable drum kit could be a great modkit starter. I mean a controller brain already seperated with leads and sensors that can be applied to any surface(actual drums maybe?)
post #3167 of 12388
Will it take the add-on cymbals?
post #3168 of 12388
Were they playing imaginary drum beats that were just inserted into the chart for the sake of difficulty?
post #3169 of 12388
Yeah Alec Van Halen isn't exactly known for his "incredible diversity" on the skins. Hot For Teacher is just double bass eighth-notes I think, with the occasional extra beat thrown in so it gives that "engine idling" effect...then its just straight to the 1-2-3-4 on the hi-hat and backbeat on the snare. By the way that beginning part, played on a single bass, would be tough to do with the rock band pedal..unless you had ankles and calves of steel. Those modern metal drummers could probably pull it off...me, i'd need double kicks
Go listen to the drums on 5150...they're pretty bad (part of it is that they are also terribly mixed), a really good song IMHO...but that guy needed a few more takes to get both the sound and his rhythm down. And by "bad" I mean lots of not-quite-on beats, like he's a half second off or something. Again, could be the mixing and reverb they added or something...but it still sounds whacked when you listen to it on headphones. Its one of the few songs I can think of where the drums just sounded...wrong, like I'd have said "Dude...dont drink tonight, come back tomorrow, and do it again!".
yeah I'm a bastard like that
post #3170 of 12388
Actually on Hot For Teacher he's playing like a shuffle on the double bass. This video has a very similar beat and explanation.
post #3171 of 12388
Songage:
Release date: Tuesday, July 22, 2008 (Xbox LIVE® Marketplace)
Thursday, July 25, 2008 (PLAYSTATION®Store)
Tracks: Nine Inch Nails 3-pack
“Burn”
“Capital G”
“Last”
Shinedown
“Devour”
“Junkies For Fame”
Price: $5.49 (440 Microsoft Points for Xbox 360) for NIN 3-pack
$1.99 (160 Microsoft Points for Xbox 360) per individual
track
post #3172 of 12388
NIN 3 pack = instant buy. Hell it'd be worth it just for Last or Burn! But both of 'em, plus another song... nice.
post #3173 of 12388
HEEEEEEEEEEEEEEEEEEEEEEEEELL YES! I can't wait for Tuesday! I still have to buy The Who pack, so it's going to be a costly day. BUT MORE NIN!! WOOOO!!!
And such good songs. I'm one of the 7 people who actually enjoy Capital G, so I'm looking forward to that one, too.
post #3174 of 12388
I love capital G, NIN is instant buy I'll have to give the shine down songs a listen first.
post #3175 of 12388
I love how Activision made their game backwards compatible with the Rockband instruments, but wouldn't let Rockband release the patch to make GH guitars work with RB. Stay classy, Activision. Oh, and go **** yourselves, too.
post #3176 of 12388
Hahaha. So right...
And I probably won't be getting the NIN pack. Not that big of a fan. Besides, I'm still busy with the Who songs.
post #3177 of 12388
I am confused, the GH 3 guitar works for me for RB? But I can only use my RB guitar with GH3? Has something changed?
post #3178 of 12388
Yes, Activision is allowing Rock Band instruments to work on Guitar Hero World Tour.
post #3179 of 12388
More NIN? Really? I will probably pick up Last. I do love me some Broken.
post #3180 of 12388
Man, every time Harmonix draws me in with the RB awesome, we see an announcement like this from the GH camp (it's GH: Hendrix for those that can't click through). At least I've got an era of renewed interoperability (maybe) to look forward to. Hopefully they do that one right. Hopefully this also signals a possibility of getting Hendrix into RB (he had a song covered in GH1, so at least there's some possiblity, but I worry that these artist centered titles also involve exclusive deals). If I weren't so lazy in regards to changing discs, this probably wouldn't concern me.
  Back to Forum: Xbox Area
