post #1 of 1
How should i place the speakers on the shelf in my columns?
Should the speaker shelf have some kind of material on it? Should the sub fire directly onto the plywood stage floor? I will be lining the inside of the columns with OC and stuffing with insulation but i wasnt sure if i should carpet / fabric the actual speaker shelves or area where the sub will fire.
