Originally Posted by
tomhayes
I am confused about the multichannel SACD issue with the Pioneer Elite DVD-48AV, can someone riddle me this?:
The DV-48AV + VSX-94TXH can
a)Output Multichannel DSD over HDMI and process that Multichannel DSD without PCM conversion
b)Output Multichannel DSD over HDMI and process that Multichannel DSD with PCM conversion
c)Output only Multichannel PCM conversion of SACD over HDMI and process that as Multichannel PCM
I see mapatton says its DSD, I just want to confirm.
Yes to all 3
Here's the how.
For A:
in the 48
Initial Settings>Digital Audio Out>HDMI Out set to Auto(DSD)
in the 94 - select Pure direct
What will be displayed on the 94 is SACD Direct
In the upper left you will only see DSD
For B:
in the 48
in the 94 - do NOT select Pure direct (any other setting will work)
In the upper left you will see DSD>PCM
For C:
in the 48
What will be displayed on the 94 is PCM Direct
