I'm having real trouble getting this to work, using V2.7 firmware on the XE1 so correct 1080P/24 output should be possible and indeed the Toshiba is trying to output 1080/24. The troule is the Lumagen then flickers all the time in the menu and movement is not al all smooth.
If I feed 1080I60 from the Toshiba to the Lumagen that then outputs 1080/24then I get a kind of "Wobble".
I have tried various settings including pass through and genlock but still no luck. Does anyone have this sort of setup working?
