Hi,
I have two DirecTV HR20 HD DVRs with the accompanying big (5 LNB?) dish. I also have an RCA DWD490RE with 3.8 on the original 35 hour hard drive. Up until recently, it was going strong.
Now I've noticed that the picture freezes occasionally as well as some accompanying box pixelation. I tested various locations and it's not the wiring in the house. From what I can tell, if I watch programming on Tuner 1, everything is fine. If Tuner 1 is recording something that is recording and I watch another channel on Tuner 2, THAT is where the problem occurs.
Is this a sign the tuner has gone bad? It had been working fine for years - do these things eventually die? Could there be any other explanation? Is it possible, say, that the UTV isn't compatible with these new 5 LNB dishes?
I would hate to say goodbye to this UTV. Is there anything I can do myself to diagnose/fix it? Thanks.
I am almost certain if you sent one in to directv for repair they wouldn't replace it with another utv?
