AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Looking for best bang for buck 42-50 inch, 1080p.
post #1 of 11
Looking for an HDTV with 1080p, 3 HDMI inputs (will go as low as 2), and from 42-50. Good picture quality of course. Looking for a good price, max 1600, but I want to pay around 1000-1200 if possible. Uses will be mostly be HD material. Anything you guys can think of?
My view distance from the TV will be about 6-10 feet (odd shaped room). Some seats are 6-8 feet away, others 10-12. TV will sit at a corner. Is 42 big enough for these distances?
Thanks for any suggestions. I have been interested in Panasonic and Samsung but I welcome any opinions. Have my eyes set on the Panasonic TH-42PZ77U. LCD also welcome though I am leaning towards plasma at this time.
post #2 of 11
The 42PZ77U model you mention is your best bet with the bargain prices available right now, dipping under your $1200 level at several stores. A 50PZ77U would be better beyond 7feet, but the cost is higher over $2000 even with the sale prices now. Another alternative is a 50" Panasonic or Samsung 768p plasma, they are very low priced now and in your price range.
post #3 of 11
At those viewing distances, I really can't see why you are considering a 42" television. Go for 50" and don't look back. Among HDTVs, size is far more important than resolution.
post #4 of 11
+1. I did a 50 inch Panny today, a non-1080p model as it will mostly be used for sports, no gaming, and seating distance from TV is about 8 feet.
post #5 of 11
How far back are the center seats that line up with the TV. From the description of the room I'd assume that it is the far corner seats that are going to be in the 6' range which is not the optimal seats anyways since you are going to tend to sit in a center position with the TV when you watch it for your own enjoyment. Because of this, I'm guessing that the majority of watching will be in the 9'-10' range???
You'd probably get the most enjoyment out of a 50" 1366x768p panel. You should be able to find a Panasonic one of these for about $1500. If you think that the 42" size is right though, then you should be able to find a 1024x768p one for $1100. I think you'll have a really hard time though finding a 1920x1080p 42" panel for any less than $1500 after all is said and done. Bigger is almost always better when it comes TVs and it will definitely have more impact on your viewing enjoyment than the jump from 768p to 1080p. Lots of HDTV is only 480p or 720p anyways.
post #6 of 11
Damn I had typed up a bunch then IE screwed up. Oh well...
First of all thanks for all your responses. I am actually doing this for someone else. One couch is 7 feet away and the other 10. I just measured from where the screen will stand to where someones head position will be. The room is in the shape of a rectangle, the TV will be on the bottom right corner of this rectangle. One couch will be on the top wall (7 feet away), the other on the left wall (10 feet away). Furniture will not move you already know how females are.
Now it looks as though you are all telling me to go with the 50 inch. I was looking at this model (Panasonic TH-50PX60U). Any opinions?
post #7 of 11
Take a look at the Samsung 5044 or 5054. Frys just had the 44 on sale for below a grand on black friday.
post #8 of 11
The obvious choice is the Samsung HP-T5064. This is a great solution for your application. Don't worry about needing 1080p. The 5064 is plenty colorful and contains lots of detail for a 768p set.
Chris
post #9 of 11
I started out with a 42" PC77U from Costco for my first HDTV, loved the picture and color, but took it back after 60 days when I found a local guy that sells discontinued and "open box"models for great prices.
Ended up getting a 50" Panasonic TH-50PX60U (manufactured in Jan. '07) for around $1200. It was in original box with all cards, manuals, etc. Pristine condition. TV works great, and I love it. The 50" 1366x768p panel provides a much nicer picture than the 42" 1024x768p panel did, and the 50" really does feel a lot bigger. I really recommend going with the 50"..
The only thing I don't like about the X60U is the the tuner is much inferior to the newer tuner in the 77U. I was getting 4 HD channels with rabbit ears on the newer 77U, but with the 60U I only get one HD channel... Oh well, time for cable or satellite...!
post #10 of 11
I purchased a Hitachi 50 inch 1080P Model 50S601 at 1.7K and I'm very happy with it. I really like the motorized mount and the picture is very pleasing.
john
post #11 of 11
I got my 50" 77U 1080p TV for $2k.
Someone else posted that they got a flyer from Microcenter for that TV for $1400....so the price on this TV can get pretty close to what you want to spend.
If you absolutely cannot go over $1500, and can't get a sweet deal....go for the 50" over the 1080p.
