I have a Samsung P1400 connected to a Denon 3300 via its 6-channel analog inputs. For some reason the analog inputs are all 4 dB lower than the other inputs (at least the ones I can test). For example, the levels using Denon's internal noise generator are nearly identical to the levels measured when using a DVE disk in my Oppo player connected via optical. The same DVE disk in the P1400 is 4 dB lower in all channels.
I have had others suggest that it may be possible to trim the levels on an individual input basis (not using the main setup level area) with the 3300, but I have not been able to find anyway of doing this.
Is it possible to increase the analog input levels on the 3300? If so, what should I do with the LFE channel? As far as I can tell, the P1400 sends everything flat to the 3300 including the LFE channel (4 dB down right now).
Is it possible to increase the individual analog channel levels in the P1400?
I have been through every setup screen I can find in both units and I cannot find anything about these types of level settings. Any suggestions would be greatly appreciated!
